Old 05-23-2013, 05:35 PM
samiam44 samiam44 is offline
Default Is there a list of good Super GT models?
I'm trying to help a friend find a good CC.
I own a 1650.. and know nothing about newer stuff. He would like a box or blade and needs a mower deck. Preferably a large deck.
We are in north Texas if anyone here knows of a good tractor.
He has 3.5 acres to cut. Maybe he needs something bigger than a cub.
Mike
Old 05-23-2013, 06:08 PM
3 and a half acres is enough to keep him busy for a while. Just my 2 cents, a Super with a 60" Haban and a Swisher 60" tow behind whould be my weapon of choice. I cut 15 acres twice a year with a Kubota BX 2660 with a 60" finish mower and two 60" Swishers behind that so it cuts 12' at a pass.
Old 05-23-2013, 06:31 PM
Maybe you should get one of these Sam..... Only one engine that way!!
On a separate note: I think a SGT would be more than adequate. If I'm going to mow 3 acres, I'd prefer a front mount ZTR mower, but you can't put a box blade on them! All supers are good. Sam likes the "one eyed" ones
Old 05-23-2013, 06:34 PM
I'be got you on the Cyclops ...
What models are one eyed besides a 982?
Old 05-23-2013, 06:44 PM
I'm not sure what you mean on the first half.... But the Cyclops is what I was referring to as "one eyed"... 982's have 2 headlights, they are not a cyclops. Sam Mac's avatar is a cyclops....
Old 05-23-2013, 06:59 PM
Sam Mac likes Cyclops, but, not enough to keep them all!!
There are a couple BIG plus' to a wider deck
One is in error of driving. The amount you overlap and loose each pass is a bigger percentage on a small deck. It seems like a 60" deck cuts twice as fast as a 44" deck. That is hard to believe, until you experience it!!
Maybe it is the power steering, steering brakes, and more HP!!
An even bigger plus is the even result of cutting with a wide deck. I have one deck that is bigger than 60", it makes the grass look like a pool table. The smaller deck dips into EVERY hole/depression. The big deck passes right over. SMOOTH!!
Old 05-23-2013, 07:00 PM
Here is a list of Supers for you
982 Onan
984 Onan
986 Onan
1572 Kubota D 600 diesel
1772 Kubota D 640 diesel
1872 Kohler Mag18
1912 Onan
1914 Onan
2072 Kohler M20
Cyclops series
1782 Kubota D 640 diesel
1882 Kohler Mag18
2086 Kawasaki FD620D
2082 Kohler Mag20
2182 Kubota WG-600 gas
2084 Kohler CH20
2284 Kohler CH22
Old 05-23-2013, 08:45 PM
jubilee's Avatar
jubilee jubilee is offline
Thanks for that listing Sam Mac! That kind of stuff is very helpful to some of us newer guys.
___________________
Jim
782 w/Command 18,
1862 not running;
IH 42 inch blade; off brand cart
Old 05-24-2013, 10:37 PM
Thanks...
I really want to lead him down a good road. Last night I seethe is a 982 forezale close w 54 deck. Says recently rebuilt motor...
It takes me 2hr to do a sloppy job o. One acre w my 1650 and 44a. Maybe I should mark the deck to know where the overlap starts.
Old 05-24-2013, 10:54 PM
Thanks...
It is marked!! On the decks with the loops, the loops are the marks.
