Old 05-27-2013, 10:39 AM
kevinandrew kevinandrew is offline
Default cub 149 rpms out of control
while mowing my 149 started to climb in rpm's. i shut the tractor down and looked it over, the govenor looked ok. so, i started it up. no change. so , i shut it down again and dragged it to the garage and found the problem: the throttle butterfly screws on the throttle shaft sheared off and the butterfly was in the intake. apparently the motor ate the screws and 'exausted' them out. i ordered new kohler screws which sheared off before they tightened up. so i drilled and tapped the shaft for new bass screws i bought at the hardware store in town. blue locktite, two 11 cent screws, new gaskets, air cleaner, and a clean carburator later and the beast lives again! lawn is mown, next week garden gets tilled. i've come to the conclusion that the old cast iron kohler is worth keeping. i'd also like to thank chris westfal, of cub classics for his advice, and available parts.
Old 05-27-2013, 06:55 PM
Glad you are back up and running kevinandrew
Got to love Chris Westfall. I have got a lot of parts from him
Old 05-27-2013, 09:53 PM
fleetlines's Avatar
fleetlines fleetlines is offline
They do something with those screws to keep them from coming out. I believe they stamp the bar to lock them in. Nice you got it squared away.
Original, Serial #44578, K161S Serial #659144, 3pt. w/ Spring Assist, Deck, Fenders, Lights
72, Serial #231093, K161S Serial #C281773, 36" deck
149 & Original Yard art
1650, Serial #2050067U559932*, K341 Serial #7133367, 3 pt. hitch
1650, Serial #2050670U601762*, K341 Serial #7584702 SIM cab, 50" deck, tires loaded & weighted
123 FEL and weight box
10" & 12" Brinley Plow, Decks, Roller, Cart, Power angle blade, dozer blade, Snow Thrower, Airator, Tiller
Old 05-27-2013, 10:01 PM
Glad to hear you are back up and running!
Old 05-27-2013, 11:02 PM
Glad to hear your cub is running again!
