Old 06-02-2013, 05:04 AM
cdlong's Avatar
cdlong cdlong is offline
Default 1450 hydro issues
Yesterday I finally got to use 1450 #2. I attempted to use the 1A tiller. I have no slow forward or reverse. Forward doesn't engage until the first mark on the dash panel. creeps a litle then fast. Reverse has to be moved 3/4 of the way down before it moves, then creep to fast. I changed the hydro filter and oil last fall. I jacked the tractor up and neutral is good. Trunion?
Papaw
1984 CCC 582 w/ creeper, 42" blade, 44C deck, 220# wheel weights, 2 link chains & adjusters, Spring assist lift.
Old 06-02-2013, 06:47 AM
I would be looking at the entire Hydro Linkage for slop and wear. Tighten up or replace worn linkage parts.
Old 06-02-2013, 08:27 AM
cdlong's Avatar
Thanks Roland. I do believe I've found the problem. This'll be a challange, I don't weld. Note how loose the springs are.
Papaw
Old 06-02-2013, 08:28 AM
That will do it.
Old 06-02-2013, 08:32 AM
Well, you may not weld, but, SOMEBODY is gonna weld!!
Good luck with the repair, that issue is frequently discussed. Many people are happy with the after-weld results!!
