Old 06-02-2013, 03:14 PM
mightycow9 mightycow9 is offline
Default SLTX 1054 Wiring Fire
Ok. So I had a similar problem to this thread. http://onlycubcadets.net/forum/showthread.php?t=5903. I had the engine start to lose power intermittently and then the tractor died. I thought it was due to very low gas level (I was pushing it). However I noticed a bit of smoke. Nothing much, no fire. We and got gas. Went to start and found nothing was going. Took me 2 hours to find the dang fuse, it was hidden from all angles and under the battery. Manual said it was under the hood. I had to twist the plastic wire cover to see that it was taped to the backside of it. Replaced the blown fuse. Started right up, sputtered, powered up and down for about 15 seconds. I saw some black smoked and at the same time the tractor died out. Lifted the hood and literally blew the flames out. You can see right where the fire started. Plastic loves to burn, so had I not blown this out I bet I would have lost the tractor.
So it looks like the fire started from the Ignition module if I am reading the parts list correctly. Probably have to replace all of the wires too. That is a pretty major malfunction of a part. Has anyone seen this?
