Old 06-22-2013, 07:34 PM
orphie orphie is offline
Default 1872 Shutdown Issues
Have an 1872 that when I turn the switch to "off", nothing happens. The way I thus "kill" it, is to choke it, till it stops. Is this a switch issue or a broken wire? What I do have is a maintenance manual, but the wiring diagram does not make sense, when I compare to the actual wiring on the tractor. The wiring diagram references a "magneto", but when I look at any parts supplier, there is no reference to a magneto. Is this term interchangeable with " ignition module" ? I am the original purchaser of this machine, so there has been to modifications of any electrical component. Thanks for all replies !
Old 06-22-2013, 07:48 PM
Could be either or.........or both.
YES. Magneto and Ignition Module are the same reference.
When you turn the Ignition Switch to off, the housing of the Ignition Switch is ground and thus the contact between M & Ground is made, killing the Magneto. So, the yellow wire could be "open" or the Ignition Switch does not make contact from M to Ground in the off position.
One other thing, this is assuming, that there is a ground connection between the Battery Negative Terminal and the Ignition Switch Housing.
Old 05-15-2014, 07:13 PM
Still the issue not resolved but tell me, does the engine need to be removed to get to the ignition coil ?
Thanks !
Old 05-15-2014, 10:50 PM
Thanks !
To the magneto? Yes.
