Old 06-25-2013, 09:08 PM
ssechrist ssechrist is offline
Default Hydro Driveshaft
Working on the 149 I noticed that driveshaft coupler on the pump has a lot of play in it. It's causing the driveshaft to turn out of alignment with a lot of vibration. It appears to be worn badly where the roll pin goes thru the pump shaft & driveshaft coupler. Not having any experience with the hydros, I am wondering what the tolerance for this connection is.
Old 06-25-2013, 10:11 PM
0. None. They should be tight! Otherwise, you get a vibration...
Old 06-25-2013, 10:39 PM
Thanks J-Mech, I thought it should be pretty tight otherwise I think it'd knock seals out or something worse. I removed the coupler from the pump & the roll pin was worn almost thru on one side, the holes in the coupler for the roll pin are badly worn, the bolt holes to connect the coupler to the drive shaft are worn some & the hole in the center of the coupler that the driveshaft fits in is very badly worn. Looks like its been ran a while on badly worn parts. Looks like a new coupler will be purchased, any suggestions on where to get one??
Old 06-25-2013, 10:43 PM
Another pic
Old 06-25-2013, 10:46 PM
And one more pic
Old 06-25-2013, 10:50 PM
Holy crap! That stuff is SHOT! What's that last pic of? The short shaft pic. Did you cut the driveshaft?
Old 06-25-2013, 11:06 PM
macman81's Avatar
macman81 macman81 is offline
I rebuilt mine with the welder and drill press. No more wobbles
John,
PROUD OWNER
Cub Cadet 122, 149, 1650 dual hyd and COZY CAB, 782 dual hyd, 54" power angle blade, qa42a snow thrower, #1 tiller w/extensions, brinly plow,
1940 farmall H, Little Wonder 2 bottom plow, 1954 IH Fridge, 1948 IH 158 chest freezer.
Old 06-25-2013, 11:09 PM
The last pic is the roll pin. I didn't cut the driveshaft, I just unbolted the two couplers & slid the round rubber plate out then removed the coupler from the pump.
Yes those parts are worn badly & know the levers & linkages aren't any better, I figured these parts were a little more important to fix first.
Old 06-25-2013, 11:14 PM
macman81, I've been thinking about that. Seems to me that the ends & the holes for the roll pin would be where the wear is. It'd be worth a try if it doesn't work I'll just buy a new one.
Old 06-25-2013, 11:34 PM
New couplers are about $55.00 from cub cadet.
How is the end of the driveshaft look?
Up to 534 and counting...
