Hi Everyone,
I'm finishing a 782 tear down and frame up resto. What are the correct washers for the front axle/wheel set up? In other words, from outboard to inboard (axle bolt to knuckle) I have bolt/large fender type washer/wheel small washer/axle shaft/knuckle. Driver's side had the smaller flat washer while the passenger side did not. Cub Cadet's diagrams for wheels and axles don't show the washers nor axle bolts so I can't get the specs or assembly sequence there. Thanks! Pics attached. |
bolt , big washer and lock washer.
does yours have the plastic caps to go over the washer
Doug Original , 100 , 125 , 582 ![]() ![]() ![]() ![]() West Central Ohio Farmall & Cub Cadet Club https://www.facebook.com/#!/groups/226681087497199/ |
It does not have any covers but based on what a previous owner did by mixing and matching fasteners and not re-installing washers where they were designed to go, they could be missing.
Appreciate any pics or explanation. Also-trying to convert all hardware to stainless-are the big washers just fender style or are they different in some manner? Thanks. |
ive only seen them on ccc tractors. there on the front of my 882 the big washer holds the wheel on. its thicker 3/16'' ish
Thanks Doug-this is a late '81 production so I guess I should have them...odd they aren't on their site. Will have to do some looking around.
if you need them i may have a set for you. was going to put um on my 582 , but not now
Doug, that'd be great. They are no longer available and I can't find them anywhere. It appears each cup requires 2 clips as well-those are available.
Let me know where you're at and how much-appreciate it. |
Post it in the wanted section. Ask for the cap and large washer just in case yours are not the correct cap washers. I'm in Greenville OH. You?
I intend to take my '95 1641 front wheels off, did so already and re-assembled.
I have a bit of horizontal play. Been there before and order washers based on outside diameter, ID diameter and thickness. Washer sizing doesn't seem to be anywhere; i.e.: service manual, partstree, wherever. A good source, fast del'ry and decent pricing: http://www.qbcbearings.com/BuyRFQ/Th...r_SL_SB_I.htm#
Tankman '95 CCC 1641 Eastern PA USMC |
