Old 07-04-2013, 06:43 PM
restore49 restore49 is offline
Default overheating 3165
Little concerned how hot my Cub is running. Good belts sharp blades clean deck(48in.) block clean and no accumulation in shrouds. Cutting 3-4 in. grass at moderate ground speed at WOT. Temperature of valve covers - 260 - down from - 280 - after setting carb richer . Would not want to sit my butt on the hood with shorts on! Should I panic??? Bob
Old 07-04-2013, 07:12 PM
What are you using to check the temp?
Old 07-04-2013, 07:41 PM
Raytec - Raynger ST - Laser unit. After mower you could not hold onto the Dip stick or touch any part of the shrouds.
Old 07-05-2013, 12:05 PM
Pa Cooner's Avatar
Pa Cooner Pa Cooner is offline
I have to mow with the side covers off of my 3235 in the summer or the oil pressure lamp begins flickering after about 20 mins.
Old 07-05-2013, 05:22 PM
I'd like to see what the temps are with and with out the side covers since you have the tool to check it.
Old 07-05-2013, 09:24 PM
I had a 3165 and the dipstick got very hot after running. If your using an IR gun, most are not accurate on anything silver or that has a shine but are on flat black. When I had mine I noticed that the drive shaft cover (duct) went up into the dash tower for the air supply but the battery blocks a lot of that area off. I wonder if that could be a problem? Would it run cooler with the cover off the shaft?
Old 07-05-2013, 09:36 PM
Will try running with side cover off (hope Cub did not make this a fix). My tunnel boot runs into lower section of dash which has large vent area above the drive shaft tunnel. Will direct gun at area under carb or flat black spot. Bob
Old 07-05-2013, 09:45 PM
I've never shot a temp gun at one of these motors.... but.... Ditch Witch trenchers used air cooled Wisconsin motors. They were WAY bigger than any cub motor and than ran really REALLY HOT. (They had trouble vaporizing the gas in the carb bowl.) I really don't think 260° sounds out of line. Aluminum melt down is about 1200° and your a long way from that. I wouldn't worry unless you get up to about 325°. Cast iron exhaust manifolds get up to 600° or more under a load. I really don't think your running hot.
Old 07-06-2013, 10:17 PM
With side covers off - 255 - no great change (checked several spots ) . Matched set of PTO belts measured - 236 / 281 so need to replace those.
Old 07-06-2013, 10:36 PM
I'm not sure what the PTO belt has to do with anything..... did I miss something?
