The electric lift on my 147 is broken. The little gears inside are worn and do not engage properly anymore.
This really wasn't much of an issue with the mower deck, I could just set the deck and forget about it. However, it makes trying to raise and lower the plow a big pain. Is there any way to convert this machine to either hydraulic or manual lift? Or would I be better off to try to find a different electric lift unit? I'd hate to sink a bunch of $$ into another lift, just to have it wear out, too. Thanks!
2008 Suzuki Hayabusa 1340cc 2007 Toyota Prius 2003 Suzuki DR650SE 2001 Chevy 2500HD 6.0L 1979 IH Cadet 85 Special Go Kart 1971 Buick Skylark 455 1971 Cub Cadet 147 |
I don't own an electric lift so I don't know for sure, but it seems like I've read somewhere that the gears out of something else are the same and can be had for a reasonable price, but I can't remember for sure.
I'm sure someone out there knows though, be patient they'll be around soon. |
I don't know specifically what is wrong with your Electric Lift, but you may try this source.....Lift Parts
The gears out of a Ford tractor oil pump Model 600-900 are the one. The can be cut down too .375 so you can get more than one out of a gear. part # FSN6600A or FPN6600B
![]() Quote:
The sponsors here might have them, too... |
just get a new actuator.
Then you won't have to worry about it for another 30 years. :biggrin2.gif:
Fly Fishing is not a sport...It's a way of life. |
![]() Quote:
Is it just as hard to find a narrow frame hydraulic setup? Thanks
I want a hydraulic setup for 124 badly!!!
But, they sell for $300+, and that's usually doesn't come with everything. I've seen complete set ups for over $500!!!! Yes, I'm sure they pop up here and there for a reasonable price, but when you're looking....it doesn't work that way. And I read all the time about buying cubs with a working setup, but then you're paying for another tractor, and if it's not close...there's shipping to add. There out there, finding an affordable one when in a bind, is another story. Try www.duffnorton.com They have some inexpensive actuators, tht should almost be a swap with original. Then you can have the original rebuilt. Or, the right way is try the sponsors sites. Someone should have one.
Don't know if this will help but my 147 has 60$ lift from canada,works great fits fine, alittle slow but dose the plow fine. You could check meyers snow plow elec lifts also.
GIG BIG PAC Daduke |
