Old 07-08-2013, 08:49 AM
mattyturbo mattyturbo is offline
Default Head Question
I just pulled the head on my k241. I did notice that the head bolts were very loose, but my understanding is that this happens and the bolts require a periodic tightening.
I wanted your opinion about the condition of piston top and the valves. The motor did not smoke even after about a half an hour of running, but you can still see a little oil. I have a new head gasket for it. I was going to clean things up with scotch brite and see how it goes. What do you think? Your help is appreciated.
Old 07-08-2013, 11:08 PM
I would try it.
Just clean it good and torque it down to spec.
Run it long enough to warm it up good and retorque the bolts and it should be good.
Just my
Old 07-08-2013, 11:25 PM
Plowboy1086's Avatar
Plowboy1086 Plowboy1086 is offline
gum gutter (2+2) and a wire brush will be your best friend
Bi-Polar Plowboy Plowboy X Press
