Old 07-09-2013, 09:33 PM
cub104boy cub104boy is offline
Exclamation Lets talk oil
I got my new tires for my 104 and it said lets change the oil in motor and tranny after cleaning the sludge in the tranny I need to know what oil you guys use in your motor and tranny. The book said SAE30 but what brand you guys use. I'm getting the oil tomorrow.
Old 07-09-2013, 09:47 PM
machinehead323 machinehead323 is offline
i use Kohler oil 30wt
1979 1650, #1 tiller with one extension, 90 degree box mounted, 3 point. 1961 4 digit bringing back to life. I have the mower and 3 pint for it. The 1650 is the fastest mower in the neighborhood.
Old 07-09-2013, 09:53 PM
jimbob200521's Avatar
You're going to get a LOT of the same answer on what fluid to run in your tranny, and that same answer is going to be hy-tran. And before you research for hours, the biggest thing that separates hy-tran from other tranny fluids is it's ability to trap and encapsulate moisture, that's probably what that sludge you cleaned out was. Only downside is hy-tran is pretty expensive.
As far as engine oil, SAE 30 is what you're going to want (as long as it's not below freezing). I use low-ash CC SAE 30 oil from my dealer because it's readily and easily available, runs me about $13 per oil change (that's for 2 quarts). If that's not available, just find some SAE 30 from a reputable brand, a lot of people recommend Shell Rotella SAE 30 and I may switch to that during my next oil change cycle because it's cheaper price wise, I can get it at Wally World by the gallon, and the quality is there.
Hope this helps, and good luck. Oh, btw, my charge is pics of your machine
-Ryan
Old 07-09-2013, 10:04 PM
Default pics
the pics for you
Old 07-09-2013, 10:29 PM
sgirdham's Avatar
sgirdham sgirdham is offline
That is a nice looking 104! I cant wait until I can afford some ags for mine.
1981 IH Built 782- 44" deck
1650 dual stick
71 "121" round fender and replacement k301 carlisle tru powers and v61
Old 07-09-2013, 10:36 PM
them ags costed me $260 all said and installed man good then they look good on there
Old 07-09-2013, 10:44 PM
Too much of a slippery slope....No comment.
Old 07-10-2013, 06:28 AM
Here is what Kohler and Cub Cadet recommends:
Motor Oil..... Oil
Transmission Fluid.....Fluid
Old 07-10-2013, 11:13 AM
SmokinJay's Avatar
SmokinJay SmokinJay is offline
What should be used in a manual trans?
108, lights, electric mower and sleeve hitch.
Old 07-10-2013, 11:42 AM
You can use Hy-Tran or 30wt oil. I'd use Hy-Tran though.
Tags
change, oil, time
