Old 07-10-2013, 05:58 PM
finz68 finz68 is offline
Default Erratic revving on barn find 1962 cc
any help will be greatly appreciated! when i open full throttle via the dash lever, the magneto lever on the engine that is attached to the butterfly on the carb by a thin rod keeps opening and closing revving erratically while the engine is running. I can only get full throttle if i manually hold the magneto lever and butterfly open. Any suggestions? I have tried playing with the 2 screws on the carb with no luck.
Old 07-10-2013, 06:06 PM
austin8214's Avatar
That lever is attached to the governor not the magneto. And I would check and clean the carb up before you go any farther. Also we need to know what engine you are dealing with in order to help you better.
Old 07-10-2013, 06:33 PM
Sugarmaker's Avatar
finz68,
First welcome.
You could have several issues?
(Yea that leaver is attached to the carb at the top and attaches to the rod for the governor at the bottom)
We just had a similar problem with uncontrolled revving on our 102 and found that the butterfly plate on the carb had lost a screw and was not functioning as it should. I agree take off the carb, clean and check first.
Regards,
Chris
Casbohm Maple and Honey
www.mapleandhoney.com
Old 07-10-2013, 06:55 PM
Thanks. I just rebuilt the carb but will take it off and check. the butterfly plate seems to have no resistance or spring of any kind.
Old 07-10-2013, 06:56 PM
its a Kolher with a Carter carb.
Old 07-10-2013, 07:25 PM
I told you the same thing in your post about the clutch.
"Go to the tech section and download the manual for your engine. The Magneto rod as you are calling it is the governor linkage. It sounds like you need to get the carb sorted out first before you damage something."
Do you expect one of us to come and fix your tractor and leave $20 on the counter?
Old 07-10-2013, 08:08 PM
sorry- first time in a forum like this and I didn't realize that I was taking advantage of all the knowledge out there. I will download the manual.
Old 07-10-2013, 08:19 PM
red56turbo's Avatar
The best thing to do is to first download the manual and read it over good. Will give ya a good idea of what you're trying to fix.
Don't apologize for asking a question. We are here to help. It just helps us steer you in the right direction if you have a little knowledge of the area you're working on. I'm sure if one of us was close by, we'd stop over and help out a fellow cubber, no charge.
Josh
Diesel Cub Cadets...........
Old 07-10-2013, 08:52 PM
Will do- much appreciated!
Old 07-10-2013, 09:25 PM
austin8214's Avatar
Is not about taking advantage of all the knowledge. It's about knowing and understanding what you are talking about so that you can explain correctly what is ailing your cub. Therefore the folks here can help you better. If you look at the carb adjust carb adjustment procedure for your particular engine that should get you close. Does your Original have the 7 hp engine in it?
