Old 07-21-2013, 11:49 AM
Nightow1 Nightow1 is offline
Default Model 70 Tie Rods????
I'm looking for a set of Tie Rods for my model 70, can anyone tell me what other cubs will fit mine. I have found some for the following models, 105, 124,1250,
will any of these work. Any help would be great.
Old 07-21-2013, 11:57 AM
Inactive Member
Since you have posted your inquiry in the "puller's section", are you looking for ends that are beefier than stock...???
Old 07-21-2013, 12:01 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
if its off any other NF it will fit your 70
Old 07-21-2013, 12:15 PM
dvogtvpe's Avatar
this is what I use on my puller. I drill and tap aluminum rod . RH on one end LH on the other to 3/8 24. I prefer the bolt through design myself . no ball joint to fall apart.
Old 07-21-2013, 01:19 PM
Get your tie rod ends here. From McMaster Carr. You can get greaseable or non greaseable. The ones I linked to are the best style, but they have other types if you prefer. You can even get them in stainless.
Old 07-21-2013, 01:29 PM
Yes I plan on beefing up the ends with Lubrication-Free Heavy Duty Ball Joint Linkages, I just needed to get the tie rods them selves mine were all bent up.
Old 07-21-2013, 01:35 PM
Oh, you are just looking for the "drag link" not the tie rods/tie rod ends......
Old 07-21-2013, 01:39 PM
Yes sorry
just the long bars, sorry everyone seems to call it something different.
Cub Cadet IH-384632-R1
Rod, Tie
Old 07-21-2013, 01:50 PM
Near as I can tell, all the narrow frames are the same. The 1250, however, uses a different part number. I don't know what the length difference is. The 147 was the last model that I saw that carried the same part number. The 149, it changed to a different number.
Old 07-21-2013, 01:55 PM
Thanks for the information. big help.
