Old 07-27-2013, 09:39 PM
D_Ordway D_Ordway is offline
Default cub 185 low boy
Hey guys im not to sure if this is the correct spot to post but i thought i would give it it a try. Well out getting some real gas i drove past a cub 185 low boy and decided to stop and look at it we talked to the owner and it starts and runs great but it doesnt drive it has a new clutch in it but it still wont go. It is for sale and i was wondering if any one knew anything about these machines and if this would be worth buying and fixing
Old 07-27-2013, 10:35 PM
rweaver rweaver is offline
ok I parted those out as well for prolly 8 years if its not moving I would look at the clutch disc or driveshaft my advice to you is those get expensive real fast that's the reason we parted them they made lots of money all the parts are big money new and used I have since sold out all my inventory but I have the guy I sold my stuff will gladly help you with parts if you buy it
Old 07-28-2013, 12:43 AM
The trans is the same as a cub cadet. They are basically an overgrown cadet. What do you want to know about them? Does this one have any options? How about a mower?
Old 07-28-2013, 07:08 AM
well i was wondering what i should offer him for it since it doesnt move the current owner has replaced the clutch he said it will creep fowdard if you move the high low lever it also comes with a belly mower he is asking 800 for it i was thinking about going to 500
Old 07-28-2013, 08:51 AM
jimbob200521's Avatar
Just my $.02 but if I came across that deal, I would get the best price I could but I would get it for sure. You could part that out and make your money back easy. Plus fixing it SHOULDN'T be too bad, but you never know for sure until you tare into them. I grew up around Cub's and Cub Lo-Boys and they are stout machines, most things can be fixed reasonably simply.
Anyway, good luck in whatever you end up doing
-Ryan
Old 07-28-2013, 09:09 AM
now that you say it moves in the low side of the creeper I would say its the splines on the driveshaft are bad if you can buy it for 500. with creeper that's a good buy does it have 3pt as well
Old 07-28-2013, 07:18 PM
gmbadgley gmbadgley is offline
Grab it before someone else does!!! I used to mow 4 acres a week with one they are one step from bullet proof!
Old 07-28-2013, 11:01 PM
..... But a little under-powered.....
Old 07-29-2013, 08:16 AM
dyt4000's Avatar
dyt4000 dyt4000 is offline
Sounds like a fun project to me! Go for it!
Co-Founder
You only need two things in life...duct tape and WD-40
If it's stuck and needs loosening, use the WD-40.
If it's loose and it's suppose to be stuck, use the duct tape.
Old 07-29-2013, 09:37 AM
QFT. Good machines but not really meant for heavy duty work such as mowing tall field grass or really any field work; plowing, cultivating, discing, etc.
-Ryan
