Old 08-06-2013, 08:47 PM
cubfan's Avatar
cubfan cubfan is offline
Default Need Suggestions for Powder Coat Removal
I have tried searching the forum for this subject but for whatever reason it wont let me using my phone and that's my only source of the internet.So does anyone have any suggestions as to how to remove powder coating. I have tried using 40 grit and 60 grit sanding disc but they clog and just smear the coating. I'm working with thin metal maybe 18 gauge so I can't get too carried away with a grinder. Any ideas would be appreciated.
Thanks
Old 08-06-2013, 10:03 PM
I guess my response is;
"Why remove it!??"
Heck, if it has protected the metal for this long, let it keep working.
Sure, PC has its problems, but, the negative is poor prep of the metal.
Where it is sticking, it will keep on sticking, IMHO,
Blend the edges, and shoot paint!
Old 08-06-2013, 11:59 PM
rweaver rweaver is offline
The way I heard works the best, is using a DA with sticky pads. The poor job that MTD did putting powder coating on, is the reason it wont stay on. At Red Power I talked to a guy who does the powder coating for MTD and there is no prep work done just shoot it. Now you know.
Old 08-07-2013, 09:15 AM
jkier's Avatar
jkier jkier is offline
http://www.eastwood.com/eastwood-s-p...strippers.html
They used to have a product called Dekote which worked very well on powdercoat.
Personally never tried whats in the link
106 Needs a clutch-------107 (Lent to my brother)
123 w/hydro lift & qa36--126 w/creeper and lift
127 restored--------------129 50" mowin machine
129 w/hydro lift-----------147 plow horse w/tiller
149 auction score---------782 KT17SII
Old 08-07-2013, 11:11 AM
hhc70 hhc70 is offline
Try some Acetone on it.
Old 08-07-2013, 01:06 PM
cubfan's Avatar
Thanks fellas,I appreciate the input.
Old 08-08-2013, 01:10 AM
For what it's worth...
Different companies make a plastic-like disk that go on an angle grinder. They look kinda like a VERY coarse very thick "scotchbrite" pad. The ones that I have used are normally blue in color and have an aluminum (or pot metal) threaded back. I have gotten them at Sherwin Williams (kinda spendy) and Home depot (much cheaper).
They do "load up" but they also wear away, so the build up does go away. They work best using very light pressure.
There are also some that fit in a drill, but most hand held drills don't turn fast enough to make very good time with.
No matter what you use, light pressure is your best friend.
