Old 08-08-2013, 09:45 PM
dutchman3119 dutchman3119 is offline
Question 982 three point hitch
I have a Cub Cadet 982 with a rear pto and three point hitch. I have problems with the tiller and brindley plow staying level and in the ground. The hitch does not float. Does anyone have a remedy.
Old 08-08-2013, 09:53 PM
It should float if it is set up correctly Mine doesn't float as much as a GT one but I have not had a problem plowing.
Old 08-08-2013, 10:48 PM
Mine is tight. I was thinking of using a piece of chain instead of the top link
Old 08-09-2013, 08:34 AM
V30crewcab V30crewcab is offline
pretty sure the rod running to the rear should have a slot in it to allow it to float. maybe someone replaced it with one without.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
Old 08-09-2013, 10:39 AM
I thought the same about the slot, so I made one on my milling machine. I was unable to lift the tiller after installing the slotted bar. It pushes to lift the tiller and pulls to lower. I checked the parts diagram and the lift bar does not have a slot. I will try a chain ( a chain is used to lift the tiller on my 123)
Old 08-09-2013, 11:29 AM
red56turbo's Avatar
The garden tractor lift bars have the slot. The supers don't have a slot in the lift bar.
Josh
Diesel Cub Cadets...........
Old 08-09-2013, 12:28 PM
Smile
I just checked the illustrated parts breakdown for a 782. You are right Red. Thanks for the info. I'll try and get some pics this weekend. The 982 is on loan to my son-in-law. I gave him a 782 with a mower deck and snow blower. I'M NOT GIVING HIM THE 982 ( TIL I DIE THAT IS )
Old 08-09-2013, 12:32 PM
cub123's Avatar
cub123 cub123 is offline
Each lift rod(#7) allows some float by sliding up and down in the lift arms(#9), If you don't grease them often they bind easy. It's not a lot of movement, but it sure helps.
Old 08-09-2013, 01:26 PM
cub123's Avatar
It hooks directly to the pivoting part that the lift cilinder attaches to, so the float pin doesn't affect it.
Old 08-09-2013, 02:24 PM
Ok, that's what I couldn't remember. By 1811 had a sleeve hitch on it when I bought it. It's not connected correctly (I don't think) and it has down pressure all the time. (Not been a problem yet because I have a floating rear link.) But maybe his is has the same problem. We REALLY need some pics!!
To the OP, do you not have the cat 0 tiller on it? Cause the way you worded your last statement sounds like you have the sleeve hitch tiller with the 3pt adapter on it.......
Your 123 should have a completely different set up (with the chain).
Does the tiller look like this? Or do you have the Cat 0 rear PTO style tiller?
I'm telling you, If you put a chain in place of the lift link #16 in cub123's post..... your asking for trouble! Or did you mean in place of the lifting rods #5? That would work, but I think your missing something. That hitch should not be making down pressure.
