Old 08-21-2013, 09:53 AM
bluesman bluesman is offline
Question Float lock out
Could someone take a minute and explain how the float lock out works? I've been using my blade to move some dirt and the blade is just floating without cutting and I'm wondering if the float lock out has something to do with this?
Old 08-21-2013, 10:25 AM
Well, you don't say if it is a front blade, but I'm going to assume it is. Also, you don't say what tractor..... I have ran all sorts of equipment so this statement comes from experience. The lock out pin, really has no place on these machines. Yes, it will enable you to put down pressure on your blade, but, let me explain something. These blades and tractors are small and don't have much weight. What makes a blade "dig" has more to do with the angle and the cutting edge. Just like with a plow. The front blade wasn't made for "digging" it was made for "pushing". There is no way to change the angle, but you can sharpen the cutting edge. The only way your going to get it to dig in well, is if it is sharp, and you use something like a tiller or a ripper to tear up the soil so you can move it. Putting in the float lock-out pin will help, but not much. It's not a bulldozer.
Old 08-21-2013, 10:45 AM
Agree 100%. If you put down pressure/lock out pin on a blade, you'll most likely end up bending the rod that connects the two. If you've fabricated something stronger, you'll likely break something else. Those blades are best used in the float position.
Old 08-21-2013, 11:08 AM
Thumbs up
10-4 good buddies, message received loud and clear. Yes, it's the front blade and the tractor is a 1650 which btw does a heck of a job moving topsoil around. I ended up with an area packed down by the tires and I was trying to cut it back down to level it. Should have got the tiller out and loosened it up first, I guess. Thanks for the info, probably saved me from a pita goof up. As always, the forum rocks.
