Old 08-26-2013, 10:17 PM
jeepchicken5000's Avatar
Default Picked up a 680 with deck and plow
Hey guys I picked up a cub cadet 680 from a kid on Craigslist, it runs and drive ok, the plow works needs a cutting edge but it came with wheel weights, tire chains, mule drive and a 44 inch mower deck, now I've never seen such a poor shape mower deck like never this bad but after cleaning it up and greasing the bearing I threw it on my 682 and it works pretty good it really needs attention but bearings sound fine. The tractor itself isn't to bad a shape everything looks original hasn't been hacked up to much only thing I see is the headlight wire to the fuse is funky but that's it. I paid 400 for all of it I didn't think it was to bad, let me know guys this is my first CCC and it's serial number is 701029.
1981 cub cadet 682
1966 cub cadet 122
Old 08-26-2013, 10:24 PM
Good looking 680 jeepchicken5000
Looks like maintenance under the belt cover wasn't a high priority
Old 08-26-2013, 10:44 PM
jimbob200521's Avatar
I'd say you got a heck of a good deal, congrats! It looks great and as l know if I had come across it, it would have been hard to pass up. Congrats!!
Edit: Aside from the deck, that is...that's just...never been cleaned is what that is. Horrible, but I can't say I take mine apart every time to clean them but I KNOW they aren't that bad
-Ryan
Old 08-26-2013, 10:55 PM
Make sure you have plenty of weights, and a new sparkplug!! The Farmers Almanac came out, and it says that your new machine will be working overtime this winter!!
Good looking machine!!
Old 08-27-2013, 12:41 AM
Nice looking tractor I wish I could say the same for the deck
Lack of maintenance there. Looks like some cobbled up patch work. But overall I think you made a good deal
Old 08-27-2013, 07:19 AM
Congrats on the 680!
Old 08-27-2013, 09:38 AM
what mike said
Old 08-27-2013, 01:03 PM
Nice score on the 680!
Old 08-27-2013, 01:21 PM
red56turbo's Avatar
Congrats on the 680. Not a bad deal at all. I think instead of using grease, they must have used dirt to lube things.
Josh
Diesel Cub Cadets...........
Old 08-28-2013, 07:34 AM
hey guys Im having a problem with the hydro linkage, its wore out so I welded up the spring retainer cause it had wore it out pretty bad got the spring to fit tight inside of it, I thought that this was a main problem with these and thought I had it fixed but it still does the same thing not as bad but it still does creep slightly backwards and if you don't stop it it speeds up . ill have to get some pics of what I did, the brake pedal returns it to neutral fine but after a second or so creeps. Do I need to adjust the linkage plate on the hydro unit up or down to fix that or is there something else.
1981 cub cadet 682
1966 cub cadet 122
