Old 08-28-2013, 04:54 PM
IH_147's Avatar
IH_147 IH_147 is offline
Default The bottom of sediment bowl fell off
My sediment bowl's bottom half fell off and I need a new one. Does any one know were to get a good one?
Old 08-28-2013, 06:04 PM
Try-
Local IH/Case dealer
Local Cub Cadet dealer
Local lawn service dealer
Posting a want ad on this forum
The sponsors at the top of the page.
Old 08-28-2013, 06:36 PM
Most parts stores can get them overnight if they don't have them in stock. My local NAPA carries them.
Old 08-28-2013, 07:38 PM
Darrell Darrell is offline
The last one i bought was made in China and the glass bowl was to small to work well. It looked like they made the bowl small to fit other sizes.
I just put a new shut off valve in the tank , a brass fitting in the carb and a rubber hose/filter. I also turn the tank around so the fitting isn't setting above the coil , in case it decides to start leaking. I guess you could do that with a sediment bowl , but never tried it.
Not sure if all the sediment bowls are made like the one i bought , just giving you a heads up.
Old 08-28-2013, 09:46 PM
IH_147's Avatar
thanks guys its really appreciated are the ones from Patton acres good
Old 08-28-2013, 10:06 PM
You can also find them on Ebay.
Old 08-29-2013, 06:07 AM
nikster's Avatar
nikster nikster is offline
I'm NOT a purists in that my cub MUST stay original, so;
I eliminated my bowl & my gas runs through a regular gas filter made for small engines.
No more issues with those glass bowls, just change my filters every spring. About. $ 3.50 each.
NIK,
Old 08-29-2013, 07:05 AM
NIK,
That is my recommendation. Get the in-tank screen shutoff, an inline filter, some fuel line, a few clamps, you are in business!!
Old 08-29-2013, 11:08 AM
For what it's worth, the nice thing about a sediment bowl is it gives water a chance to settle out BEFORE it gets to the carb bowl. It's really the only benefit of using one nowadays. Fuel filters have come a long way since then.
Old 08-29-2013, 11:40 AM
Doesn't the ethanol absorb the water?
I haven't seen water in the bottom of a gas can in years!!
At least the water can no longer rust the bottom of a steel gas tank!!
