Old 08-29-2013, 10:17 AM
ravenseye ravenseye is offline
Default Blade - Narrow frame to wide frame
Got a call yesterday from someone I just bought some wheels from who said he has a snow blade that will fit my 782 except that it's set up for a narrow frame. He suggested that I bring it to a welder who could adapt it to fit. I'd rather not have to adapt anything and some searching here leads me to believe that I can look for a sub frame that would fit my WF 782 and then hook the blade up to that with no further modifications. Does that sound right? If so, any thoughts on how hard it will be to find the right sub frame or should i just start melting metal to make it all work?
Old 08-29-2013, 11:05 AM
cjrolke cjrolke is offline
i would find a correct wf subframe
you need something like this
what is on there is like this
not saying you cant make it work but it may be easier to get the right thing
Old 08-29-2013, 12:16 PM
As stated above, find a WF subframe. I had to do the same thing this past Spring. My blade was originally used on my 100. Now I use it on my 782. You'll also need the correct lift rod and bracket.
