Old 09-03-2013, 04:03 PM
sgirdham's Avatar
sgirdham sgirdham is offline
Default Sleeve hitch Plow question
I just got lucky and scored a free plow from my neighbor. It was converted to fit a Cat 0 three point for a sears but it still had the sleeve hitch part with it. My question...Is the hitch attachment supposed to have the angle like this one or should it be straight with the plow? Maybe this sounds funny, refer to the pictures and you will see what I mean.
1981 IH Built 782- 44" deck
1650 dual stick
71 "121" round fender and replacement k301 carlisle tru powers and v61
Old 09-03-2013, 04:45 PM
It's supposed to be angles like that. You run a plow with one wheel in the dead furrow, so, that angle makes the plow level with the ground.
Old 09-03-2013, 05:01 PM
sgirdham's Avatar
That was fast! Thanks for the tip, i have never used a plow but it makes sense now.
1650 dual stick
Old 09-04-2013, 09:39 PM
cc_bob cc_bob is offline
If you are planning on welding that back on be sure to bevel the edges first to get full penetration. I'd hate to see it break on ya.
I like to keep em running and work them.
1872 (I call her Vera), 782D, 154 Loboy (w/tiller, 3260 deck, and front blade), 3-1650s, 2-1000s, 149, 147, 106, 1810, Farmall Cub, Haban sickle bar (not mounted), No. 2 trailer and several parts tractors.
Old 09-04-2013, 10:06 PM
sgirdham's Avatar
It is designed to be bolted together. I may or may not weld it because one of the bolt holes was torched to a larger size to accomodate a PO mod. I am familiar with beveling edges before I lay a bead. My navy days gave me plenty of experience in metal working.
1650 dual stick
