Old 09-04-2013, 03:58 PM
druwl druwl is offline
Default Governer
Got the 1250 running. Every time I try to rev the engine it dies. Carbs been cleaned and partially adjusted.
Disconnected the governer linkage. Idled up using the carb bracket, engine dies. With idling I moved governer linkage and no change.
I'm thinking the governer needs looking at.
Yes - No??
Old 09-04-2013, 05:08 PM
austin8214's Avatar
Adjust your carb per the manual those setting should let it run then fine tune it from there. I highly doubt your Governor is the problem.
Old 09-04-2013, 05:41 PM
Yep, definetly not the governor. Could be fuel or timing. My bet is on fuel.
Old 09-04-2013, 08:43 PM
Okay - http://www.onlycubcadets.net/pdf/QL%20Op%20Manual.pdf
I've set the 'high speed adjustment' screw at 2 turns and the 'idle adjustment' screw at 2 & 1/2.
No change
I've also noticed that it will ONLY run with the choke about 90% on.
Ideas??
Old 09-04-2013, 08:46 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
2 turns isn't far enough out. they say 2.5, but that's just a preset. you have to adjust it from there. I've noticed its usually closer to 3 turns. but it depends on the engine. that's why its just a starting place
Old 09-04-2013, 08:48 PM
dvogtvpe's Avatar
has this thing been sitting? if so did you clean the carb and sediment bowl?
Old 09-04-2013, 09:22 PM
Far as I know, which isn't much, it has been sitting. We did clean the carb and it wasn't bad.
I'll try 3 turns on the screws.
I did back the throttle set screw off. No change
Using my hand as a choke it comes away wet??
Tractor serial #20500 63U536066
Engine Kohler serial #640482
Old 09-04-2013, 09:25 PM
dvogtvpe's Avatar
put new gas in it?
Old 09-04-2013, 09:41 PM
Yup, flushed out the tank and put on a new fuel line. The lid one was to short/fat and interfered with the throttle linkage.
At 3 turns it seemed to do marginally better, but after burning myself on the muffler box I'm still stumped as to why the choke needs to be on???
Going to look for sympathy from the wife.... lol
Oh yeah! The carb gurgles after it dies.... Strange stuff
Old 09-05-2013, 06:34 AM
dvogtvpe's Avatar
if the choke has to be on you're not getting gas. something is partially plugged , kinked or dirty restricting the fuel flow to the carb or in the carb.
Sorry no sympathy for burns. man up or put a skirt on.
