Old 09-09-2013, 04:29 PM
johncub7172's Avatar
Cool Little bit of paint today { picture heavy }
Had a chance, so cleaned up this transmission just a wee-little bit, see here......
Then I added some primer. About 3-4 coats to my liking,.........
two close up pictures,......................................... ........
Old 09-09-2013, 04:37 PM
Cool
the last close up,.........
That's about it for today!
Old 09-09-2013, 06:01 PM
That's cool! But, how did you keep those axle tubes on with no bolts?
Old 09-09-2013, 07:18 PM
nice work
Old 09-09-2013, 08:56 PM
Apparently the axel housing are sealed that good! They have not had bolts in a while, and never leaked any lube. I even took a rubber mallet and hit all around the housing,..... nothing. I wanted to replace with bearing bushings, but the standard 72 wheel bushing in this trans are like bran new.
Thanks cubcadet!
Old 09-09-2013, 09:27 PM
Nice work johncub7172
Old 09-10-2013, 04:34 PM
Thanks Diz Jr. ! That was some mighty elbow grease to get the transmission down like that. So glad to see it in primer! There is still a lot to be said and done to this part, but at any rate I hope to have it in Cub Cadet Yellow before it gets too cold to paint outside.
On a side note, I did however manage { on my lunch break of course } to get to my local Cub Cadet dealer and ordered the following parts:
seal - oil...............{rear wheel seal}............................................. ....$7.03 x 2 = $14.06
IH 376216-R2........{reduction housing/trans block} gasket.............$11.81
IH 384725-R2........{reduction cover} gasket.................................$6.19
total=......$32.06
The Cub Cadet dealer is on my street, so for the sake of the sale I get my parts there.
Old 09-10-2013, 09:51 PM
Nice work, John!
Old 09-11-2013, 02:17 AM
CadetTY's Avatar
CadetTY CadetTY is offline
Lets see some more!
What did you use for primer?
882 diesel, x3 ih 582, 73 124, x2 82 seriers pullers, 1686 16hp puller
Old 11-22-2013, 09:22 PM
Originally Posted by CadetTY View Post
Lets see some more!
I use Martin Senour Cross/Fire sealer, then I went on to a self-etching gray primer of the same amount of paint coats. Thanks!
