Can anyone recommend a souce for the fuel filter (the cannister one) for a 782D? I'm good with using our wonderful sponsors, but I don't see any of these FS with them.
Thanks John
John, I use Wix filters and they are:
Air = 46270 Fuel = 33389 Pre Fuel = 33972 Oil = 51064 Hydro = 51410
I just rebuilt a JD 332 with the three cyl diesel in it and I went with a K&N filter with a little adaptation. It is washable and should last many years. If you have the measurements of the old filter you can go to the K&N web site and find one that is really close and use it. The one I bought for $35 is washable and the one that JD sells is $35 and has to be thrown out every season. Measure the hole in the one you have and the outside diameter and then you can make it work for you.
1811 Hydro "Failing to prepare is preparing to fail".
I also use Wix in both diesels and my vehicles. They have a very high rating for particulate removal.
Don Smith https://www.facebook.com/SouthernKentuckyCubCadetClub IH 982D aka "The Big Red Smoker" BRS w/3pt hitch CC 1572 aka "The Big Yellow Smoker" BYS w/3pt hitch-PTO Brinly Cat 0 3pt plow-Brinly sleeve hitch plow Custom Hydraulic lift disc-Haban Blade-Brinly Cultivators Cub Cadet lawn trailer and lawn sweeper |
I go to my local Kubota dealer for all my 1572 engine parts, including filters. My Cub dealer gave me that advice! Use partstree to get the part numbers. Any Cub part number that starts with KB is an actual Kubota part number.
My local NAPA auto parts store carries or can get most filters for my 1572.
982 with 3 PH, rear pto, front & rear hydrs & ps, 1772 w/3 point, rear PTO, 86, 2 Haban 60" decks, Haban 54" snow/dirt blade, Brinly Cat 0 Disk, 5' blade & 2 Cat 0 Plows, SpeeCo Cat 0 plow, Sears cat 0 Cultivator, Cat 0 CC 442 Tiller, 60” rear mower, 450 blower |
i use all NAPA filters, which are made by WIX.
127 - 48'' deck + tiller. 1512- 46" GT deck & bagger 1872- 60" Haban 1772 turbo diesel- Iron rear + KW loader + backhoe + 3 point. Case 580CK Ford 850 International TD-8E |
I use the factory filters as well. They do not cost that much more. I buy them by the case of off ebay.
