Old 09-18-2013, 01:59 AM
Default Float lock-out "apparatus"?
From what I can tell, the wideframe implement float lockout tidbit is just a plate with a hole and a dowel pin it that goes through another hole that locks the two halves of linkage together...
My question... Why can't you just put a regular bolt in that hole that locks the two linkages together? I don't really see what the plate, according to the manual, is supposed to be doing.
Sorry if this has been asked and answered a million times before.
Old 09-18-2013, 02:28 AM
cubby102's Avatar
cubby102 cubby102 is offline
I have used just a bolt in the past. But drilled the tip of the threaded end for a hitch pin to hold it in
Old 09-18-2013, 07:15 AM
OldAndInTheWay's Avatar
I have the same question. What harm would be done if the are joined?
Old 09-20-2013, 12:09 AM
Thanks for the feedback!
Good call on locking the fastener. Sounds good to me!
Old 09-20-2013, 05:34 AM
ddsmith60 ddsmith60 is offline
If we leave the lock out pin or bolt in there, and put the deck on, we may be able to use the deck as a lift for tire changes. Just kidding. It looked to me like the spot where you would put a pin or bolt was not round but more slotted on one side. I wonder if that was just me not seeing it right.
Old 09-20-2013, 10:31 AM
sawdustdad's Avatar
I think the only reason for the plate with the hole it it is to allow you to turn the dowel around and keep the little plate attached to one of shafts with a cotter pin so you don't lose it.
