Old 09-19-2013, 10:58 PM
boxccc boxccc is offline
Default IH CC 124 Lift handle (3 pt) + Clutch adjs. ?
In the process of installing a creeper gear for my 124 (which I did from the bottom and not separating the tractor), I thought I took enough pictures to help etc. the reassembly. (Wrong) I can't seem to get the lift handle properly connected back to the rear 3 point hitch in the rear. I can't find a schematic in the available manuals. Anyone have pictures or a schematic???
Second problem: After reassembling the repaired creeper gear (badly worn internal yolk) and hooking up drive shaft , clutch etc., all started well and the creeper gear / tranny worked as long as i had the clutch release lever tightened considerable to the clutch release rod but the safety starting lever would not contact the safety switch till I interposed a wooden peg, it then started and ran nicely. I then attempted to adjust the clutch release rod and noted the more I loosened the compressing nut, the closer the switch lever got to the switch. The engine would start but there was little or no motion in any gear. I am thinking that the clutch is slipping because of the loosening at the clutch release rod.
I am hesitating to bypass the safety switch. I tried adjusting the position of the safety starting switch lever but it did not help. Can that lever be safely bent or should I weld a pieced to take up the space? Or what am I doing wrong (among even starting this project)?
Refer to my threads about the saga of the creeper gear conversion under "boxccc" for more details if interested.
Old 09-19-2013, 11:38 PM
As far as the 3pt is concerned:
Pic 1:
Pic 2:
Part #3 in pic 1 attaches to part #6 in pic 2, EXACTLY as they are shown in the pic. With the lifting "bar" on the frame side.
As far as you safety switch is concerned.
The safety switch #18 is adjustable on the rod #11. Simply move it where it needs to be AFTER you correctly adjust the clutch. The clutch is adjusted correctly when you have to move the pedal down about 3/16" off it's stop as per the tech manual for that machine.
Old 09-20-2013, 10:19 PM
Default CC 124 Lift Handle
J Mech: Thanks for your help and schematics. I spent the day reassembling and attaching the lift handle and its push rods to the 3 point hitch and the tractor. As I stated before, I was in the process of removing the drive shaft / clutch apparatus from below being erroneously informed that it was a simple operation(wrong). In order to get to the parts I had to remove the cross bar holding the lift handle and the foot pedals. I didn't take enough step by step pictures and I kept blindly removing nuts and bolts to loosen the apparatus out of my way, then some of it fell out and I didn't record their arrangements/ order.
This info is for anyone who might be ensnared as i was. I had to trial and error several times till I got the reassembly right. The #s refer to the schematics you provided above.
1. The #9 (u shaped bracket) has to be placed first outside or lateral to the lift handle.
2. The #8 (ratchet tooth semi circular) bar has to fit into the narrow clef of the lower part of the lift handle above the handle locking pin.
3. Secure the lift handle/cross bar to the rt and lt of the frame using the triangle pieces #10. Especially if you are doing this alone, without extra set of hands.
4. Then bolt the bracket #8 and #9 to the frame.
5. Then slide #3 (rotatory section of the long #4 shaft) into the bottom of the lift handle just above the cross bar and secure it with 2 bolts.
I found this step by step sequence was necessary because the individual parts did not allow manipulation to gain their needed position.
First 3 photos denote #8 #9 sections.
Next 2 denote #3 #4 attached to bottom of lift handle base.
Hope this helps someone in the future doing what i did.
