Old 09-22-2013, 06:17 PM
Calvins66Cub's Avatar
Default Gas Tank Repair
I finally decide to fix the gas tank. I rinsed it THOROUGHLY with water. I found 2 pinholes that were leaking. One was near the seam, and the other was near the filter. I fluxed and soldered both areas, then just for fun I had some grey paint left over from another project. I put some electrical tape between the tank and its mount...couldn't hurt.
I am going to make a new front pulley for the engine from steel with a larger diameter to charge better at low speeds. No PTO. Has anyone done this? Advice for size? Can the generator spin too fast?
Also, Is this the stock clutch guard?
Thank you all for your help and input. This is fun!!!
Old 09-22-2013, 07:13 PM
OldAndInTheWay's Avatar
Model?
Tank looking good.
Old 09-22-2013, 07:21 PM
cubs-n-bxrs's Avatar
The flip side to putting a larger size pulley would be that it will not turn the engine over as fast when trying to start. Maybe not fast enough to start it. Yes that is a stock clutch guard. Looks like you have a 102 or a 122 by the looks of the headlight cutouts in the grill.
Old 09-22-2013, 08:05 PM
Yes, it is a 122. '66.
Old 09-22-2013, 09:52 PM
I had a 1966 model 122 and the battery was installed different from yours.
Plus you should get the correct style hold down to reduce the chance of an electrical fire/mishap.
Old 09-23-2013, 01:23 AM
I agree with Kelly. There is really no reason to change it. These machines charge fine at idle. Besides, then you have to center and weld the clutch "basket" to the new pulley, and what if it won't spin fast enough to start? Some mods are good. But sometimes its better to leave well enough alone.
Old 09-23-2013, 06:43 PM
Thanks for the input. I only use my 122 for goofing around. I let my kids, supervised, tinker/drive it. I mainly use it at idle, and it doesn't kick in to charge until just under half throttle. It has a new voltage regulator, charges fine, but not at idle.
Being a machinist with a full shop to my disposal I am looking for a project too.
