Old 09-25-2013, 06:54 PM
IH_147's Avatar
IH_147 IH_147 is offline
Default snow thrower belt please HELP
well snows around the corner and i need help with the drive belt not sure how to get it over the mechanical pto arm please help thanks zach
Old 09-25-2013, 07:09 PM
cubby102's Avatar
cubby102 cubby102 is offline
You have to open up the gap by undoing the turnbuckle on the pto arm that connects it to the dash lever. Then it will fit right up through there
Old 09-25-2013, 07:10 PM
IH_147's Avatar
got a pic a direction
Old 09-25-2013, 07:21 PM
Is this on a 147? Follow the rod past the turnbuckle back to the rockshaft on the dash tower, there should be a quick pin/cotter pin holding the rod to the rockshaft. Remove the pin and shove the rod as far forward as you can (obviously after you've already put the lever on the opposite side in the "engaged" or on position) that should give you a lot of clearance between the PTO and the arm for the belt. Reverse order for operation.
Old 09-25-2013, 10:11 PM
rweaver rweaver is offline
you better clean the rust off the pto pulley or you will be replacing the belt shortly
