Old 09-25-2013, 09:18 PM
EarlJ's Avatar
EarlJ EarlJ is offline
Default 125 Shifter won't move
Recently I went out and fired up the 125, when I shifted it in gear the shifter leaver wouldn't move. I finally was able to "force" it, and she pulled and drove fine. I just can't get it to shift easily as intended. The last time I used it it was business as usual. Any ideas? What the fix is, why it would just lock up like that?
126 in surgery with weights, spring assist, 3 point and sleeve hitch
100 with woods finish mower and rear lift,
Nice 125 with super nice sweepster, 1782 Super Diesel,
1650,782D in surgery, 102 parts tractor..
3 Brinley plows, Brinley cultivators , rear scrape blade, front plows and custom built bedder attachment.
Old 09-25-2013, 09:30 PM
cjrolke cjrolke is offline
could be the brake part that centers the hydro held it from moving
when was the last time it was used?
I bought a 123 that didn't want to move at first but it finally moved and it was the brake pedal that was kind of holding it
Old 09-26-2013, 02:08 PM
There is a nut in the dash that controls the tension on how much force is applied on the hydro lever. My initial thought is that some how it got seized up momentarily. I would try hitting it with PB blaster, as well as the linkage points to see if that helps.
Old 09-26-2013, 11:37 PM
EarlJ's Avatar
Thanks I'll check on that if I can get home in time this weekend...
Old 10-06-2013, 10:15 PM
EarlJ's Avatar
I got a chance to check it out today I disengaged the shift rod from the trunion bracket. It moves freely and I cannot move the shift linkage...looks like I'm going to have to tear the tower down to clear up the issues in the the tower... I'm thinking there is quite a bit of rust hanging out in there...
Old 10-07-2013, 07:37 AM
Thanks for the update!
