Old 09-28-2013, 08:07 AM
bhunter bhunter is offline
Default Rear wheel assembly for GTX2100
The GTX2100 I purchased several days ago is running great. I ordered a set of Carlisle Tru Power lugs which came the other day. I am going to use them for the summer time and keep the factory ones on with chains for blowing snow as most of you suggested. I want to purchase a set of rims for the lugs so I can just switch out rims and tires. I called the dealer and they stated that I will need bearings also. All the photos I am viewing only show a rim that bolts on. I did not take the wheel weights off yet but , my question is, wouldn't it be like a car, take one wheel and tire off and put the other one on. I just want to make sure the dealer isn't trying to sell me something I do not need. Thanks for any input.
Old 09-28-2013, 08:57 AM
gcbailey's Avatar
gcbailey gcbailey is offline
I did the same thing on my GT2544, I believe Cub has used the same 4 bolt wheel hub for years and years. I got a pair of the 2 piece wheels from an older 3000 series and put a set of Carlisle All Trails on them.... Best thing I've done to it.
Gary
Old 09-28-2013, 08:20 PM
Xtreme makes an adapter that allows you to use the Cub 5 bolt rims on the 4 bolt axles. click on the tires, rims section and scroll down
http://www.xtrememotorworks.com/Part...rts%20List.htm
Old 09-28-2013, 09:35 PM
cub123's Avatar
cub123 cub123 is offline
I can't understand why in the world they want to sell you bearings, all you need is an extra set of rims.
Old 09-28-2013, 11:12 PM
Juicybusa Juicybusa is offline
If the caliber of parts people are no better than some I've run across lately, I'd bet they are looking at the front wheel assembly.
Old 09-29-2013, 08:07 AM
thanks for the info guys, I specifically told them (dealer)that the rims are for the rear.
