Old 09-29-2013, 08:49 PM
Green stripe wide frame's Avatar
Green stripe wide frame Green stripe wide frame is offline
Default It's alive!!!
i got my 108 running yesterday after buying it in june with a broken rod and not knowing what else could be wrong. i had the block bored .020 and a valve job with new exhaust valve used a crank, rod, and piston i had from an engine with scored cylinder. after i tightened the last bolt my hands were shaking i filled it with gas and oil pulled the choke and it fired right off then i jumped on it and drove around the yard for about 15 minutes with my daughter she loved it, then i finally ran out off gas because of debris in the gas tank tomorrow im going to pull the tank and clean it out then retorque the head bolts and put the mower on and cut the grass wish me luck
Old 09-29-2013, 09:10 PM
Super!! Glad you got "new life" in your cub and it sounds like your daughter is too if you drove it so much you ran out of gas! You may want to put a filter on that fuel line if the tank is really nasty in there for better filtration. Can't wait to see your pictures of your cub 108. Sometimes all they need is a little TLC...
Old 09-29-2013, 09:19 PM
awesome! hope you get the bugs worked out!
Old 09-29-2013, 09:47 PM
Good luck
Old 09-29-2013, 10:14 PM
Glad you got your 108 running!
Old 09-30-2013, 06:14 AM
X2!
Old 09-30-2013, 07:00 AM
OldAndInTheWay's Avatar
Old 10-02-2013, 04:01 AM
http://www.youtube.com/watch?v=xos2MnVxe-c
