Old 01-17-2010, 04:53 PM
jfinney's Avatar
jfinney jfinney is offline
Default QA latch springs
On my 149, the Quick attach latch does not stay in place. There was a long spring looped onto a homemade bracket that held it in place. I bought the latch springs, but can't seem to figure out how the go on the tractor. I thought there was a topic about this discussed earlier, but I can't seem to find it. So, anyone have a picture or diagram showing how they go on? Thanks,
Jason
Old 01-17-2010, 05:30 PM
Is this what you are looking for....???
Old 01-17-2010, 05:54 PM
wshytle wshytle is offline
Jason-
These springs are about the easiest fix on a cub. You don't have to remove the latch bar either. The picture R Bedell posted show all you need. With the latch bar held up, just curl the spring in place and make sure you get a good "bite" with the fish hook looking end. This is all that holds them in.
Hope this helps.....Wayne
Old 01-17-2010, 08:31 PM
jfinney's Avatar
That's great, thank you very much! I'm assuming there are only two (one per side), and that the picture is showing what it looks like inside by placing one on the outside? Thanks again,
Jason
Old 01-27-2010, 08:53 AM
jfinney's Avatar
Thanks all...I installed the springs and everything now works as it should. I can get rid of the ugly bracket and LONG spring the PO put on the tractor to make it work.
Jason
