Old 10-14-2013, 05:55 PM
Default Magnum Ignition
I have been working on a M-20 in a friends tractor. He had an interment spark issue (LH) side. Sometimes the engine would run smooth, then out of the blue it would run on only 1 cylinder. This was driving me crazy trying to catch it and then trace it down. I couldn't figure out why it had spark on one side and not on the other. Spark comes from the same ignition module for both sides. I was contemplating it was that the LH had rubbed through & grounding out....NOPE. Well, I finally found it today. Turns out to be the Spark Plug Wire snap end. Cut open the boot.& pried the old one off. I happen to have a plug wire laying around. Installed the new (newer) end along with a new boot.....Lo & Behold Huston, we complete ignition. Now, I would have never thought it would have been a bad wire end. Attached are pictures. And yes it is somewhat distorted to get it off, but the condition of the end says a lot.
Old 10-14-2013, 06:20 PM
EricR's Avatar
EricR EricR is offline
Nice going Roland, it just goes to show how we all need to start with the easy things first.
#10-149 with a 38inch deck.
2015 Kubota BX 2670.
Old 10-14-2013, 06:32 PM
What Eric said!
Old 10-14-2013, 06:33 PM
Roland
This is why I call you Dr. Roland you ROCK BUDDY ! The Master of all things that make smoke in the wires.
Old 10-14-2013, 10:06 PM
Way to go, Roland!
Old 10-15-2013, 05:53 AM
Thanks guys.
I thought I would bring this to light in case anyone else would have an Ignition issue with just one side on the Magnum Series.
Old 10-15-2013, 11:02 AM
Like Eric said, sometimes it's the simplest things that are the hardest to find. Good job Roland!
Old 10-15-2013, 11:09 AM
cubs-n-bxrs's Avatar
Great trouble shooting Roland.
Old 10-15-2013, 11:45 AM
Gaden's Avatar
Gaden Gaden is offline
Thanks guys.
Yes, this is a good one to file away, problem is, sometimes those little guys up there in the file room can't find it.
