Old 10-18-2013, 02:47 PM
cjrolke cjrolke is offline
Default 123 trans leak
I have a cub cadet 123 that has a trans leak
I assume it is from the cork gasket what else should I replace as I am going through the trans to help stop some leaks ?
I have put new orings on the relief valves already and new filter and fluid
just want to stop the drips
thanks
Old 10-18-2013, 03:26 PM
There are four shaft seals - Input shaft, output shaft, LH Control Arm shaft, and RH Control Arm shaft.
Old 10-19-2013, 07:55 AM
cadzag72 cadzag72 is offline
my trans leak was traced back to a cracked suction tube where it went into bottom of the rear end housing. see if you can track down the area on the rear end where it seems the most damp. you may have to split the tractor, but better to find the culprit than guess and check over and over.
Ian
Old 10-19-2013, 05:16 PM
The guys are correct!
If you are gonna spend the time and effort to tear it down, then replace all the seals and check all the plumbing. If you do it right you should be good for years to come.
Keep in mind that the stems on the release valves have "O" rings on them as well and they do go bad. It is quite a project to repair them, most folks either get rebuilt ones or just let them leak. Someone correct me if I'm wrong but I think rebuilt ones are about $70.00 each. If yours are leaking and you have or are building a "no problems" machine, they are worth the investment.
Old 10-19-2013, 05:38 PM
EricR's Avatar
EricR EricR is offline
Mark the Ebay guy rebuilds 2 for that price. I had 2 of them done and will use his services again.
#10-149 with a 38inch deck.
2015 Kubota BX 2670.
Old 10-19-2013, 06:21 PM
Juicybusa Juicybusa is offline
I had two rebuilt-work great-zero problems
Old 10-19-2013, 07:09 PM
Very good, thanks for setting me straight!
Old 10-19-2013, 07:44 PM
This is the guy that does the valve rebuilding.
605 Furnace Rd.
Conneaut Ohio 44030
Phone: 440-499-5813
Email: mark.machtech@gmail.com
E-Bay add
$35.00 each plus $4.95 shipping ($4.95 flat rate regardless of amount)
That's both valves rebuilt for only $74.95
Old 10-19-2013, 08:33 PM
my valves are good
( well they were stuck and are now good)and I put new orings and the nylon backs in it to get the tractor moving
I have a new cork gasket coming to hopefully solve the leak
thanks
Old 10-19-2013, 09:06 PM
Originally Posted by cjrolke View Post
my valves are good
The rings that we were talking about are on the inside of the valves (the valves have to be machined apart and crimped back together.
But if yours aren't leaking from around the stem, you are good to go.
