Old 10-26-2013, 11:03 AM
Green stripe wide frame's Avatar
Green stripe wide frame Green stripe wide frame is offline
Default My new snow thrower
I just picked up my QA42A last night and is in better shape than I thought. I picked it up for $60
Old 10-26-2013, 11:08 AM
great find
Old 10-26-2013, 11:09 AM
I hope you have a receipt because at $60, you stole it
Great deal
Old 10-26-2013, 11:31 AM
DITTO...Call the law
Old 10-26-2013, 11:55 AM
Awesome buy!! Be sure and service it well before using it.
If the chain is rusty, it should be soaked in some good penetrating oil and lubed good before use. If in doubt, replace it. They should only run 15-20$ at any implement store worth their salt. Just take the old one with you so they can match it up.
Good luck!
You are gonna love that thrower. What Cub are Ya gonna put it on?
Will work best on a hydro or if you have a gear drive w/creeper.
Old 10-26-2013, 12:13 PM
jonjunk's Avatar
jonjunk jonjunk is offline
Good deal! I just picked up one for $80 not adjustable tho
122 PTO, lift, deck, weights, and chains clist pick
123 headlights no motor came with the 122
Stx38 free acquisition but its the wrong color works great though
Free craftsman gt 17hp Briggs Intek hydro
Old 10-26-2013, 02:33 PM
i put the snow thrower on my 125 and i have this issue of where the suports on the side rub on my grill frame am i missing something
Old 10-26-2013, 10:51 PM
Nice score!
Old 10-26-2013, 10:56 PM
Nice find Green stripe wide frame
Old 10-27-2013, 11:26 AM
It kind of looks like that pin in the arm has two washers on it, if so then you might try removing one of them. Make sure that all of your bolts on the grill and frame are tight in that area--see if you can make some small adjustments on them to re-center your front nose piece, if you can spare room on the other side. If not, then you could put a longer pin in and use washers as spacers to adjust the arm out on the side to where it won't rub.
BTW: Sweet Deal!!!
