The lift cylinder for the deck also powers the front blade. The blade does not have and power down. I took the cover off and found the lift arm just hits the bracket when going up, then rotates free when going down. It looks like their is a spot to put a bolt through with a nut welded to the lift arm to lock it.
Just wondering if that,s what it,s for. |
YUP, I guess you can say, the hydro system, by default, is "free float". IF....you want down pressure, you will have to install the "locking pin".
That's what I thought, is it just a single bolt with a collar on it? Do you have any pictures of it? Thanks for the info
You need to be careful when putting the lock pin in I have seen this bend what is # 2 in the diagram. It is not very easy to get out and straighten. I have also seen the roll pins snap and this is also not a quick fix.
Charles________________________ 1572 3pnt, rear PTO, 50" deck 1772 3pnt 50" deck, Brinly Plow, 54" Power angle plow 1872 3pnt, 44" deck, Brinly Plow, 54" Power Angle Plow 2072 3pnt 50" deck, Brinly Plow 2072 50" deck Cub Cadet Tank 50 Zero Turn Cub Cadet 33" Commercial Walk Behind 1953 Ih Cub with just about every implement New Holland TC33D with Loader and Backhoe |
I had the same idea you have on my dual stick 1650 when I got the push blade. I think I asked the same question you're asking, I also got the same advise about being careful or I may break or bend something.
But being the thick headed person I am I went ahead and locked it in for down pressure. Worked great for a little while till I snapped the spirol pin. It is a bugger to change. Lesson learned ![]() ![]() So coming from someone who's been there, done that, be carful while applying down pressure.
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
I just finally found the manual. I think the lift bar for the rear 3 pt attaches hear, but you also have the option to have power down on front attachments when the bolt is in . I went out and put a bolt in to lock it and the lift bar for the front blade bows out when powering down. I think that's the part that will fail/flex before a roll pin brakes.
Yep one of the most fun jobs on a Cub is changing the spirol pins in the rock shaft. you get to use lot's of cool tools like a cutting torch, BIG hammers and you also get you use a lot of great 4 letter words. Let us know how that works out for you.
I used a bolt to "Power down" when using my Johnny bucket but I realized that the little pin on the rock shaft was where all the stress is and not the grade "8" bolt I used. All I can say is that if you really want to have a reliable power down system you would need to weld the arm to the shaft.
1811 Hydro "Failing to prepare is preparing to fail".
Thanks for the info on the roll pin and past experience.
