Old 11-02-2013, 08:26 PM
Default Heavy duty log splitter advice
First off, before I started looking around, I didn't realize that, in todays market, my idea and manufacturers and suppliers idea of a "heavy duty" log splitter was so vastly different.
Anyway I'm looking for a bad a$$ log splitter or "firewood Processor" (as some would say).
Something perhaps like the one in the video here.
http://www.youtube.com/watch?v=hhmKBDIAXd0
I don't need all the bells and whistles though, just something with a hydraulic lift and capable of splitting large diameter logs.
Old 11-05-2013, 12:01 AM
I just had time to set down and re-read this post and realized that I never did ask a real question.
The question is, does anyone have any first hand knowledge of a good heavy duty log splitter?
Old 11-05-2013, 12:58 PM
Shaner Shaner is offline
in my opinion, there is no "heavy duty" wood splitter on the market today. sure the ones at tractor supply are nice, but they aren't what they are supposed to be. you would have much more luck making your own. ive seen wood splitters using a hydraulic cylinder from a cat dozer before and it would split anything you put it in. if you built your own splitter, you could build it to your own specs, and as heavy duty as you wanted. skys the limit if you have a GOOD welder and a set of torches, band saw and grinder.
Old 11-05-2013, 01:16 PM
OldAndInTheWay's Avatar
This one would be cool.
http://www.youtube.com/watch?v=X0-1Rx1NNDY
Old 11-05-2013, 01:39 PM
mmzullo mmzullo is offline
Here's mine that I built about 10 years ago. Most of the stuff came from Northern tool. 5 hp honda. Jib crane and winch from harbour freight. Built from an old Lickity spliter(frame and wedge). X wedge I made. Back is shot so thats why I put on the crane instead of the hydraulic lift. I can drag a round from 50 feet away if I want to. Wireless remote also. Haven't found a piece of wood that it wont split.
Old 11-05-2013, 06:54 PM
Here is mine,home made,picked it up cheap,added some stuff,still working on getting the log lifter.This has a 12x12 I beam that is 8' long and the tank is is part of it.24" ram 16gpm pump,8hp kohler.
Whoever made this was a good welder,Has a rear from a front wheel drive Chevy.I know it weights a ton.
Up to 534 and counting...
Old 11-05-2013, 06:59 PM
Mark
Here you go. This will Git Er Done.
http://www.youtube.com/watch?v=YeanPDO-D6M
Old 11-05-2013, 08:17 PM
See, now here is where I think an old gear drive with the rear PTO would be cool. Instead of having it's own motor, build a splitter that hooks to the cub, and the rear PTO runs the hydraulic pump. Then, one motor to maintain instead of two, and, you get to use the cub! How much more could you ask for!
Old 11-05-2013, 08:21 PM
Mark
That is absolutely the coolest splitter I have ever seen!!
Old 11-07-2013, 10:51 AM
would the direction it spins and how slow it spins have any effect on how much volume it would pump? i know the one on my 122 spun really slowly compared to a normal PTO on say a ford 8n/9n
