Old 11-08-2013, 06:10 PM
bocephus1991's Avatar
Default Converting to wheel studs
I want to change my 1200 from having bolts that hold the wheels on to studs. Can I just get the appropriate size bolt (7/16-20x1.5) run them in from the back them get automotive lug nuts to use ? I did notice that all the factory bolts are is grade5,I don't see why I would need grd8. What have other people done? Changing tires without having studs is a giant pain in the butt!
Brian
Old 11-08-2013, 06:20 PM
It's easy to deal with the bolts, here is a little trick I learned from my BMW days. All you need is a long bolt, cut the head off and screw the remaining part in the hub. That will make it easy to slip the wheel on and then you just put the remaining bolts in.
Think you can get this kind of info at any other site?
Old 11-08-2013, 06:34 PM
You do that too I see....
Old 11-08-2013, 06:41 PM
Yep great minds think alike.
Old 11-08-2013, 06:55 PM
Check out this thread too
http://www.onlycubcadets.net/forum/s...ad.php?t=27951
Old 11-08-2013, 07:08 PM
Yes but I use 2 of um...
Old 11-08-2013, 07:17 PM
cubby102's Avatar
cubby102 cubby102 is offline
I've been thinking about going with sams stud kit. Only problem is I have four tractors and I'd like to do it to all
Old 11-09-2013, 07:15 AM
cadzag72 cadzag72 is offline
I do this too! Like Lew, I use 2 as well, and I do one more thing: I take a die grinder and cut a notch in the end of the bolt so I can use a flathead screwdriver to install and remove them. I have a pair for cubs and a bigger pair for the lo-boy. as much of a pain cub wheels can be, the lo-boy ones are 10 times more!
Ian
Old 11-09-2013, 08:31 AM
cubs-n-bxrs's Avatar
I went down to the local Fastenal and bought a 3ft piece of hardened threaded rod. I have converted a couple of my cubs to lug studs. They sure look purdy with chrome lug nuts on them.
Old 11-09-2013, 10:30 AM
Really, you can do it easy..... Kelly's (cubs-n-bxrs) is the simplest. Or you can buy a true stud. Or, just buy the right lug studs. They have a knurled shank on the stud that will smash right into the threads on the old wheel hub. Might even have to drill them a little. Should be able to get what you need at any auto parts store. Just look through the wheel stud book to find the dimensions you need. Usually around $2.00 - $3.00 a piece.
