I went to put a cast set of axle carriers but I found they have the bushing in them instead of bearing. Is that a problem if it going on a hydro rearend (982the alumimum ones are shot) I know these carriers were used on gear drives.
Are you talking about the axle tubes? The axle carrier is the differential.
yea tubes I thought I changed it to tubes
I thought the originals were the ones with the bushings in the axle tubes.
![]() Parts tree shows needle bearings in the gear drive tractors.
1641, 1541, 682 with 18hp command engine and hydraulics from a 782. 1872 with a power angle blade. |
a 102 was one or other depending on vin
Yes 102 and 122's can be either way.
Those bushings were standard on the model 72. Not positive about the 70/100 series, or the 71 and 73. As long as the bushings don't look worn, I don't see why you cant use what you have. But, since you are this far along in the project, it was told to me that you need to press out the bearing, install the same way. Axel seals are under $7.00 each. Maybe you are one of those who can improvise and remove and install these axel carrier bushings or bearings thinking out side of the box. I have a picture somewhere of what I think look like excellent bushings.
IH CUB CADET 1450, 72, 86, 1211, IH #2 CART, IH 56" SNOW BLADE, COLLECTING CUB CADET ENGINES |
