Old 11-10-2013, 09:43 AM
Default Need a head for my 149 in a hurry...
Fired up the 149 this morning and all was well. It's cold here (37F) so I let it idle out for awhile before putting it to work. Got it all set for my first stripe of mowing (leaves mostly) and it just died about 40ft in to the first pass...
The culprit? A loose plug that took the threads out of the head on the way with it. I tried to chase the threads and it won't even bite the tap. On the motor, the head is done. Maybe I can heli-coil it and keep it as a spare, but regardless.
I need a ready-to-run head for my 149. I'm not interested in any repairs more elaborate than a new gasket, replacement head, and clean-up, this late in the season.
Sooo... If you've got one, name your price, shipped.
Thanks!!!
Old 11-10-2013, 10:20 AM
macman81's Avatar
macman81 macman81 is offline
Not trying to tell you what to do but a helicoil kit is around $35 and stronger that original was. And you could be back running today.
Just my .02. Have a good one!
John,
PROUD OWNER
Cub Cadet 122, 149, 1650 dual hyd and COZY CAB, 782 dual hyd, 54" power angle blade, qa42a snow thrower, #1 tiller w/extensions, brinly plow,
1940 farmall H, Little Wonder 2 bottom plow, 1954 IH Fridge, 1948 IH 158 chest freezer.
Old 11-10-2013, 10:42 AM
gmbadgley gmbadgley is offline
Helicoil it and forget about it. you will never have another problem with it.
Old 11-10-2013, 10:46 AM
I hear you completely and I agree... I've installed heli-coils before and am familiar with them.
That said, I just bought a head that doesn't need repaired for $28 from another member.
The bigger point is about how I choose to use my time vs. money. I'd rather have a "sure thing" showing up in the next few days vs. my skills (or lack there of) with a repair kit.
Plus... "today" is going to end for me shortly. The only reason I was at it this early is because I was "still" up!
Anyhow, thank you for your feedback!
I'm still in the market for another-another head. I can't see that having a couple of spares is going to hurt (although this is the first time in over 25 years with that tractor that this has happened).
