I just took the batteries out of my Cubs and want to keep them in the best condition for the winter. I have 11 and was wondering if a battery tender will work with them hooked together in parallel. I have a couple of big batteries out of my boat that I think will have to be done separately because of their size.
I have never tried this and wonder if someone here had. Thanks John
Original, 109, a pair of 122s, 124 with power lift, 124 with creeper, 126, 147, 1050, 1200, two 1250s, 1450 Dual Stick , another 1450, two 1650s, Gannon Earthcavator, Haban sickle bar and a bunch of other things you either pull, push or hang underneath. |
I was wondering the same thing John. I remove my batteries and move my chargers around. It would be nice to jump them in parallel and keep them all charged.
I don't see any reason why that wouldn't work. But the amp output of the charger would be split between all the batteries. You might have to run the charger on high, or get a bigger one.
I've done it many times. I have used jumper cables to connect the batteries and used my little battery tender. It takes a little longer to come up to full charge but has not damaged anything. In a pinch at work, I've even used a battery jump box to charge a battery. I hooked the battery box cables to the battery and plugged in the battery box charger. The next morning it was fully charged.
Bill |
Sorry to jump your post, but on the subject. I have trouble with my battery loosing its power during the winter I use it to blade and sand my drive. The battery is new and like 350 CCA, do the Battery Tenders work and would this fix my problem of having to jump it every time?
149,682,1641,1711 with a 12hp in it 1 8" brinly plow 1 10" brinly plow 451 snow blower,H-48 International snow thrower 42" york rake with fold down grader blade. |
The tenders work well. Mine is always plugged into it.
Cub 104 Refurbed Sprinig of 2013 Aftermarket headlights, 3 point, Brinly Adapter, Spring Assist, 42" IH Blade, 42" Mower Deck, 42" Craftsman Grader Blade, 10" Brinly Plow, 6-12 ags and 22x9.50 turfs |
As an added benefit to keeping your battery fully charged, it also keeps the battery warmer than ambient, since there is intermittent electrical activity (natural/parasitic draws and the recharging) On brand new equipment with a new battery, it always starts easier when left on a trickle charger than if left off even over night (no there are no parasitic draws.)
Without a doubt, if you don't have one, get one. The cheap ones are fine for maintaining charge, and when you can pick one up easily for under $10 it is almost ridiculous not to use one over the winter. |
Great Thank you.
