Old 12-03-2013, 09:44 AM
Inactive Member
Default 442 Tiller acquisition!
Sorry guys it took me so long to get this on here... too many things going on! Anyway, I picked this up over the Thanksgiving weekend... got an excellent deal on it!!
The PO of course messed up the shaft so I managed to pull things apart and see what I have. In the process messed up the spider gear but hopefully that won't be too expensive. The question is... do I need to have the 13/8" piece of shaft welded back on the the existing shaft or is there enough shaft left that I could use what I have?
Old 12-03-2013, 09:53 AM
Need to see the shaft laid out in line in the order that it goes together and also what you are calling the "Spider Gear" I think your talking about a U-joint cross?
Old 12-03-2013, 11:17 AM
Glad you got the tiller, Darrell!
Old 12-03-2013, 11:26 AM
Congrats on the tiller Darrell!
Old 12-03-2013, 01:33 PM
Inactive Member
OK Sam... I'll lay it out on the table with the pieces and parts and take another pic... I realized after I was loading the pics this morning that I didn't take the pics I thought I had... Yeah, on the farm we called them spider gears... u-joint I guess is probably more appropriate. All the little needles in the cap went flying across the floor and of course I can't find them all!
Old 12-03-2013, 04:59 PM
This may answer some of your questions about PTO shafts.
http://www.mytractorforum.com/showth...o+shaft+length
Granted they are talking about 540 RPM shafts but the idea is pretty much the same. Keep in mind that if the shaft is too long it can damage something and if it's too short it can come apart.
Old 12-03-2013, 06:11 PM
Leadslingingdaddy's Avatar
I have a Cat 0 tiller with all the correct items. Let me know if I can help in any way. Also check TSC as they have a wide variety of PTO items.
Old 12-03-2013, 11:54 PM
rweaver rweaver is offline
depends what tractor you put it on you may want to change the one yoke any way if it has the original small drive line they don't service those the next size up they do same as most lawn and garden small compact size pto shafts we have a shop near here that fixed me up for my 4ft IH tiller when one of the caps was off
Old 12-04-2013, 07:56 AM
Well from looking at his signature I would bet it would be goinig on a Cub Cadet Super of some sort...? (But I may be wrong he may have a green one lurking in the shadows)...
Can you give us a Google translation on this? : -)
Old 12-04-2013, 12:43 PM
Inactive Member
Hey guys thanks for all the help!! I will be putting the tiller on a super... just don't have it yet... My 1572 has the rear plate for the PTO drive, it just doesn't have it installed (never has and probably never will). If I can get it started, I'll hook it up and see how things look... I put the shaft back together without welding the little piece back on but I kept it just in case... Anyway, I'll report back with how it looks...
