Old 12-04-2013, 06:21 PM
KayakDon's Avatar
KayakDon KayakDon is offline
Default 2182 dual hydraulics
I have a 2182 and just bought a 54" blade with the hydraulic angle option. I only paid $125.00 and got new tire chains for 26" tires thrown in! Now the question. What valve do I need to add a second hydraulic valve and front ports? I just bought this valve "Cub Cadet 1772 Super GT 2 Spool Hyd. Valve 717-3025" on Ebay, but now I'm pretty sure its not what I need. I think from some of what I've been reading is a second valve to stack onto the original. What and where to get the parts I need would help a whole lot. I use a snow blower for the snow, this blade would only see dirt and sand, not that makes any difference LOL.( I guess I'm saying I'm not racing the snow). TIA Don
Old 12-04-2013, 07:45 PM
Don
I have the valve you need thanks to CubyFan, problem is I don't have the connectors that go between the 2 valves so that you can stack them and they are NLA from Cub. They used to sell a kit for the Cyclops tractors but it is NLA. I’ll do some digging and see if I can get you some more info.
Old 12-04-2013, 08:06 PM
TIMCRUTCHER TIMCRUTCHER is offline
If it is the "square" valve like on my 1782 the fitting is still available from cub. It's about $12 plus the O rings and backer washer. Need to look under 3000 series to find the part.
Old 12-04-2013, 08:10 PM
That's the part he is going to need. I'm going to defer to you for the part number. That or give us a 3000 series model number, I looked around at the3000 stuff and didn't find it.
Old 12-04-2013, 08:21 PM
Here is a pic of the dual sticks I added on my 3k tractor. Look in the (365)cat 0 parts section page 4. It is part #711-3294, you will need the rings with it also if they don't come with it. I probably have a few extra laying around if you can't find any.
Old 12-04-2013, 09:05 PM
That is why OCC is the best! You guys rock! We don't need no stinkin MTD to Git Er Done!
Old 12-04-2013, 09:09 PM
I used part # 711-3294 with o rings 921-3021 and o ring back up 721-0492 to add two new valves. I learned that you do not need to "over" tighten the 1/4 bolts that hold them together. It can bind the valve and not allow you to move the lever.
Old 12-04-2013, 09:13 PM
No idea what it looks like but MTD is proud of it
711-3294 ADAPTER-VALVE $18.69
I would like to get my hands on one and see what it would cost to have them made.
Old 12-05-2013, 02:49 PM
gdheck's Avatar
gdheck gdheck is offline
Sam,
If you give me a little while, I can provide the dimensions of the part. I bought one a while back so I could have a pattern to make my own.
Unfortunately, by the time you buy the material and pay the shop to have one made it would be very expensive. I'm guessing that part would be at least $50 by the time you get it. My time for pet projects doesn't have a lot of value at times or I wouldn't make my own. I'm also sure that they will be NLA within a few years and I still have decades of working on Cub Cadets ahead of me.
For some of your general hydraulic needs, check out Baum Hydraulics in Omaha, NE. I get a lot of my hydraulic stuff there. Request their catalog. I'm not a fan of their website.
Geoffrey
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 1872, 2072, 2-1864's, 1782, a few 42" front blades, 2 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
Old 12-05-2013, 05:39 PM
Here is a pic of the part...I think they mark it up just a little.
length is 0.837"
small tube OD is 0.336"
small tube ID is 0.249"
large center spacer part that is centered is 0.563" OD and is 0.118 thick
me not a machinist
let me know if you guys want anymore pics. this should be pretty easy to make.
