Old 12-06-2013, 07:37 PM
Fwoolley Fwoolley is offline
Default To spindle or not to spindle
I'm pretty sure my spindles are shot or at the very least my bearing and seals are.
How do I determine if I should replace the whole spindle (two total) or just rebuild?
And how do I loosen the blade nut, spindle bolts, and spindle rod nut??
Old 12-07-2013, 07:41 AM
Need more info before we can answer. Like the model number of the deck and a few pics would help.
Old 12-07-2013, 11:46 AM
Deck Assembly part number is 683-0611
Not sure of Deck Model #
Mower Model # is 13A-201F100
Serial # 1G092H20495
Series 1515
2001
Spindle Assembly part # is 618-0676
Spindle Housing Assembly # is 618-3129A
Thanks
2001 1515 Cub Cadet
288 hours
Model 13A-201F100
Old 12-07-2013, 12:22 PM
Just looked at it on Cub's parts site. Looks like you need to take an impact wrench to the nut that holds the blade on. Then the spindle shaft should come out from the top. They don't show the bearings as being replaceable. Once you get it apart you may be able to get them out of the housing and match them up. Probably cheaper than replacing the complete assembly as Cub wants you to do.
Old 12-07-2013, 01:17 PM
Ok, I'll get her cracked open and check it out. Thanks
2001 1515 Cub Cadet
288 hours
Model 13A-201F100
Old 12-07-2013, 01:45 PM
This is the drawing from the Cub site with the other parts for the deck deleted. When you look for the part try Cub Cadet (whatever part number) on Google. You should be able to find it for less than Cub.
Old 12-15-2013, 06:31 PM
Default Grease?
Any benefit to using any particular grease? I also have a boat that uses marine grease for the axles, does it matter if I use that on the spindles or something cheaper?
2001 1515 Cub Cadet
288 hours
Model 13A-201F100
Old 12-15-2013, 06:49 PM
Just my 2 cents but I use Mobil 1 grease in all my stuff that get's greased with a grease gun.
