Old 12-07-2013, 10:22 PM
mike melillo mike melillo is offline
Default Help please; Identifying Pressure side
My memory is lousy, and I don't want to bend the tubing twice. Can someone help confirm that #1 in my image is the pressure side?
I think the allen screw plug gives it away but I really want to be certain.
Thanks
Mike
Old 12-08-2013, 08:47 AM
Yep #1 is pressure and #2 is return.
Old 12-08-2013, 09:35 AM
gmbadgley gmbadgley is offline
The return/suction side ports should always be larger than the pressure side.
Hydraulics 101.
"If I can't fix it, I can screw it up so bad no one else can either"
Old 12-08-2013, 10:29 AM
Hydraulics 101.
Both are the same size #6AN at least they are on the Cyclops Supers.
Old 12-08-2013, 01:11 PM
OK 99% of the time.
Old 12-08-2013, 01:24 PM
OK 99% of the time.
You are right about most systems. They probably wanted to cut cost so they made them the same.
Old 12-08-2013, 01:27 PM
thanks guys, it would have been a nightmare having to correct that post assembly
Mike
Old 12-08-2013, 08:11 PM
hey, you had a 50/50 chance!!
Old 12-09-2013, 09:02 PM
based on my experience, when I have a 50/50 chance I loose 100% of the time. I can't figure out why exactly that happens
Old 12-09-2013, 10:06 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
ME TOO!!!
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
