Old 12-12-2013, 10:40 PM
whaler12 whaler12 is offline
Default 1811 and 450 blower
Hey,
I have an 1811 I just picked up and also have a 450 blower to put on it, they were purchased seperate and now I'm trying to mount them up. I have the blower mounted on the tractor but am unsure where the lift rod mounts to on the 1811? Any help would be appreciated.
Thanks,
Pete
Old 12-12-2013, 11:02 PM
rweaver rweaver is offline
you need a bracket that bolts to the outside of the frame on the rockshaft looks like a long triangle so it pushes forward to lift the blower
Old 12-13-2013, 12:21 AM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
http://www.xtrememotorworks.com/Part...rts%20List.htm
It is the second item down under Snow Blower/ Push Blades. I have the exact same setup this year since I pulled the motor from the 2072.
I don't think the bracket is absolutely necessary, it just reverses the direction of lift. Someone correct me if I am wrong.
It just occurred to me, the float lockout pin may need to be installed if you don't have the bracket?
I am going to hook mine up this weekend, and maybe placing my second order with Xtreme.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 12-13-2013, 02:42 AM
Note on extrememotorworks page: It doesn't "link" well, the provided link just takes you to the main page. You have to click on the tab on the left "snow blowers/push blades. (Shrewcub: good link, just wanted to explain it doesn't take you right to it.)
Yes, the bracket is necessary.
Just for clarification here is a pic of the bracket installed. Note: I have the blade on right now, not the blower, so disregard the lift rod.
Old 12-13-2013, 08:06 AM
Thanks a lot
Old 12-13-2013, 10:22 AM
Shrewcub's Avatar
Thanks for the clarification, Jonathon!
I just went and looked at the 1811. It appears that the rod would hit the frame / side panel if it was hooked to the top of rockshaft arm.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
Old 01-01-2014, 05:09 PM
Thanks for the help so far, yes it looks like if the rod will hit if attached on top of the rockshaft. Another issue I'm having is that the bracket I bought from the linked website, hits the bar on the underside of the frame that support the running boards. I've attached some pics. What am I missing? I know that the rockshaft height stop has been cut off but that shouldnt be a problem.
Old 01-01-2014, 06:19 PM
Flip it around, it goes on from the front. Look at my pics from above.
Old 01-01-2014, 07:23 PM
I saw the way you had it mounted, but the lift rod will hit the side panel of the tractor if it is mounted up high like that. My rod has a hole in it that will go on the bottom of the bracket with a cotter pin. What am I missing?
Old 01-01-2014, 08:12 PM
I think what J-Mech is saying is the piece you purchased goes on the opposite way you had it on. It goes in front of the rock shaft.
( Am I correct? )
{additional info } I think the lift rod goes underneath, not on top.
