Old 12-13-2013, 02:00 PM
sbauerz28's Avatar
Default 450/451 snowblower fan spline repair
I created this thread to show how I repaired the stripped splines in my 450 snowblower fan. I wasn't about to spend $160 on a new fan when I could respline this one for about $15. I guess if you had to pay a machinest to do the work your cost may be a bit more.
I started by purchasing the correct 13 tooth 7/8" ID splined coupler. See the link below.
http://www.surpluscenter.com/Power-T...413-1-1392.axd
Next, the remaining splines and some extra material need to be bored out of the fan so the new splines can be pressed in and welded in place. I bored the fan hub to 1.0625 ID. That is the difference between the OD of the fan hub at 1.250 and the ID of the splines at .875.
This is where I'm at now. I will finish with the repair tomorrow morning.
Old 12-13-2013, 02:14 PM
sbauerz28's Avatar
I forgot to mention that I bored the hole 1.250 deep and it cleaned out most all of the splines. This is also the length of the splines on the gearbox shaft. This must also be bored on center so you don't have any vibrations.
Old 12-13-2013, 05:04 PM
Nice job!
Old 12-14-2013, 05:46 AM
sbauerz28's Avatar
Here it is all ready to weld. Turned the coupler down in the lathe for a tight press fit into the fan. I also added a chamfer on the fan hub so I can fill with weld and grind it flush.
Old 12-14-2013, 07:05 AM
dag1450 dag1450 is offline
Great idea ! It's just so sad that u wont see any of that to show it off. Mayb while u r doing all that work to the fan u could check it for balance, it may have been what started the whole problem. Dave
Old 12-14-2013, 07:22 AM
sbauerz28's Avatar
I think the main cause was that the gearbox shaft was not set deep enough into the fan splines. There is alot of in and out adjustment for the gearbox and you could tell only half the spline depth was engaged. I'm also thinking that the PO engaged the PTO at full throttle and not at idle.
Old 12-14-2013, 08:10 AM
sbauerz28's Avatar
This is the finished fan after welding. Looks good I think. Now I just need to install it in the snowblower and try it out.
Old 12-14-2013, 08:24 AM
Great job!
Old 12-14-2013, 09:10 AM
Calvins66Cub's Avatar
Nice job on the repair!
1966__122 Cub Cadet.
Owner: Calvin, 6 yrs old
Dad: Craig
Old 12-14-2013, 09:15 AM
"Looks good I think." That is way better than good! That is as good as it get's! Outstanding repair!
