Old 12-15-2013, 08:22 AM
jimbob200521's Avatar
Default Is the CH185 18hp Kohler from a 2185 a worthy replacement in a 682?
I found this locally and am thinking about making an offer on the motor because I'd like to have a transplant ready when the KT17 Series I in my 682 eventually dies
http://rockford.craigslist.org/grd/4240200214.html
-Ryan
Old 12-15-2013, 08:29 AM
Buy the whole deal. Then put the trans on FleaBay. Keep the drive shaft so you can do away with the rag joint.
Old 12-15-2013, 08:30 AM
Exactly what I was hoping to hear, I just hope it's still available! Thank you!
-Ryan
Old 12-15-2013, 09:26 AM
Leadslingingdaddy's Avatar
Your lucky I'm not closer! That is a steal.... then put a 20hp Carb on it and you will be set.
Old 12-15-2013, 09:51 AM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
X2
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 12-15-2013, 10:34 AM
cubs-n-bxrs's Avatar
I have a Command 18 in my 682 converted to a 782. The motor is fantastic. I would love to find another one.
Old 12-15-2013, 10:54 AM
my next question is since this is a cupcake that motor, will the mounting holes lineups with the ones that are on the 682 or will I need to do some kind of fabrication? And how about the electrical system?
-Ryan
Old 12-15-2013, 11:34 AM
SS5150's Avatar
SS5150 SS5150 is offline
I saw that ad too, if I didn't have a girlfriend upset about my 782 and newly acquired 1710 parts rig I'd have that in my garage already.
RUN IN THE RED
782 w/50c deck (red); 782 dual stick, 44c deck (y/w);
1050 w/38c deck; 1864 w/54" GT deck;
1872 project
Cub Cadet Pro Z 560 L
42" power angle snowblade, #2 tiller, 2-QA42a snowthrowers, 450 thrower, #2 cart; 54" Haban blade; Brinly box blade, 48" dethatcher, moldboard plow; Agri-Fab sweeper
1200, 1863, 1864 parts machines
Old 12-15-2013, 11:51 AM
You will have to drill 4 new mount holes in the plate which is no big deal. As far as the wiring goes I used the 2185 harness in my 682. Couldn't see cutting up a good 682 harness. Had to extend a few wires and shorten a couple others. I soldered all my connections and used heat shrink tubing to cover them up. I fabbed up my own driveshaft using the old shaft from the 2185. Very pleased with the results. You will either need to fab up your own muffler system or see if you can purchase one fron a cyclops with a command in it. I fabbed up my own.
