Old 12-15-2013, 09:02 PM
c69ss396 c69ss396 is offline
Default What is this?
This came with my 122 but I have no clue what it is and where it goes.
Old 12-16-2013, 01:46 AM
macman81's Avatar
macman81 macman81 is offline
well i can't tell you what it is but I'm pretty sure its not an IH cub cadet part. none i've ever seen at least.
John,
PROUD OWNER
Cub Cadet 122, 149, 1650 dual hyd and COZY CAB, 782 dual hyd, 54" power angle blade, qa42a snow thrower, #1 tiller w/extensions, brinly plow,
1940 farmall H, Little Wonder 2 bottom plow, 1954 IH Fridge, 1948 IH 158 chest freezer.
Old 12-16-2013, 03:34 AM
cubby102's Avatar
cubby102 cubby102 is offline
I've hand every nut and bolt of a 122 out and this doesn't look familiar at all. Maybe something a PO made.
Old 12-16-2013, 09:06 AM
What ever it is, by the looks of the pin it's pretty well worn out!
Old 12-16-2013, 11:54 AM
..... looks broken whatever it is.
I'm pretty sure that isn't a cub part. I've never seen that.
Old 12-16-2013, 12:06 PM
Me either. Could be homemade.
Old 12-16-2013, 01:00 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
That is a toggle switch safety cover from the formerly top secret CC122 guided missile interceptor project.
The DOD wanted a portable, inconspicuous, suburbanite friendly unit that could also mow grass while on weekly patrol in subdivisions.
Old 12-16-2013, 01:35 PM
kostendorf's Avatar
The small hole is for the safety wire to keep the bikini clad girl from accidentally shooting the missile.
Old 12-16-2013, 01:45 PM
kostendorf's Avatar
What it actually is ---- A brake pedal lock to lock brake pedal down. I have one on my 460 farmall. When you press brake pedal down you lift up on a rod to catch this piece on the brake pedal arm to lock the brakes. When you step on the brake again this piece lets go by way of a spring that is connected to the small hole.
Old 12-16-2013, 02:12 PM
kostendorf's Avatar
I couldn't find a pic of everything put together and I don't want to walk all the way out to the shed in the snow to take a pic., but I do have a pic. of the brake pedal that it works on.
