Old 12-28-2013, 05:22 PM
offroadphotog offroadphotog is offline
Default On this episode of "Big Dumb Loads"......
So the village didn't like my trailer in the front yard. My 24' x 8.5' trailer that weighs #3750 pounds empty which it is. I am not able to move into the acceptable position with my truck due to the tight turn radius so it was up to the Cub 102. I welded up a hitch and bolted it to the rear end. I was skeptical that the Cub was going to be up to the task, this trailer is ridiculously tounge heavy. But I kinda didnt have a choice. On top of the task itself, there is 3" of wet snow cover.
I was honestly completely surprised at how well it handled the trailer. Aside from my from my front tires barely touching the ground, I had no issues moving the trailer. I was in 1st gear with the creeper engaged and the throttle was at idle. It didn't hardly even put a load on the engine. I am impressed with this little Cub!!
Heres the proof
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 12-28-2013, 05:30 PM
Great job with the move!
Old 12-28-2013, 05:41 PM
Glad the Cub Got Er Done and I'm glad I don't live in a town that has a problem with a nice looking trailer in the yard. Don't they have better things to deal with?
Old 12-28-2013, 05:54 PM
Yeah I didn't know know it was against any code at the time of move in because other people had similar things in the front yard. However they don't allow that stuff to be in the yard during the winter. Lame. Other than that snafu, my lifestyle seems to fit within the other regulations so its not too bad.
Old 12-28-2013, 06:27 PM
That's an impressive looking hitch set up. I've moved some heavy trailers/loads at my parent's place with Dad's 125 when I lived there. Going slow and steady is the key. Was your trailer empty?
Old 12-28-2013, 06:37 PM
Thanks. I wanted it as overkill as possible since i was worried about tounge weight. The trailer was empty but its an all steel frame and comes in at #3750.
Old 12-28-2013, 06:42 PM
Muzzy Muzzy is offline
I'm not surprized. I move trailers all the time with my 123. After all, it's an IH cub cadet!!!
Old 12-28-2013, 06:43 PM
Maple Cabin's Avatar
Maple Cabin Maple Cabin is offline
Can we see the mirror setup on the CUB
Nice move.
Doug
126 Creeper,H lift,Deck, Sleeve hitch, B Plow, Weights
129 Deck, Blade, Weights
1200 Creeper Deck: 1250 B Tiller odd deck
782R with power steering
JD 110H:JD 112H
Old 12-28-2013, 06:54 PM
Nice move.
Ha, mirrors. It wasn't too bad actually, i would jump off and check occasionally but with it being a flat front, i was able to keep it in the direction i wanted it to go.
Old 12-28-2013, 06:58 PM
dgrapes59 dgrapes59 is offline
Interesting, I was wondering what I could reasonably tow (move) with a Cub Cadet. I have a car hauler trailer, about 1,800 lbs empty I think, with pretty heavy tongue weight. I also have to put it in a spot that eliminates using my truck (back into a barn & turn it sharp). I use a 2-wheel tongue dolly now, takes help to push (not fun) and the weight is likely more than it was designed to move, thinking it will fold up on me soon.......
Nice hitch set-up, you got me thinking now!
Thanks for sharing,
David
